- Mar 29, 2011
Hi again,
In addition to ebaying a small premade forge to get started, it turns out a buddy had a bernzomatic he never uses, minus the little disposable tank.
I've seen people say you need an adapter to use the bernzomatics with a large/conventional propane tank (which I'm going to have anyway for the forge).
Are all of the 20 lbs tank to 16.4 / 14.1 oz appliance adapters pretty much standard/compatible?
Will I need a regulator on the hose or is running straight from the 20 lbs tank thru an adapter hose to the torch dandy?
Thanks
edit:
Sorry, found this thread http://www.bladeforums.com/forums/s...b-tank-to-torch?highlight=bernzomatic+adapter which is pretty much the same question word for word!
Thanks
edit:
