- Feb 16, 2010
Hi folks, I recently purchased a blast cabinet and compressor to try my hand at this type of finishing. I set the compressor at 100 psi and began with med. glass bead using an 1/8" nozzle. On a heat treated SS blade there was very little effect if any but on 6AL4V it made it cloudy but did not remove much if any of the handling marks present when I buy it. Not a very nice look.
THEN I removed the glass beads and put in silica sand everything else the same. The finish on the blade was a little courser than I wanted but thought it might be acceptable until I saw that I had warped the shit out of it. Bad deal. I did try the titanium and it also warped that however that was a scrap, the blade was not! I turned everything off and here I am begging for help. Any advice would be appreciated.
Thanks, Gene
Thanks, Gene
