- Nov 23, 2003
Does anyone have repeatably good results on soldering? S30V blade to 416SS Guard.
Man, I hate soldering guards for the following reasons:
1) I can't ever get the solder to flow at the low temperature that it should . . . no matter how clean my parts are.
2) I always scorch the nice finish on my blade and guard, and have to come back to try to clean them up again.
3) I'm afraid that I'm compromising my heat treat, although I take multiple precautions such as wrapping the blade in a wet cloth, using heat blocker, etc.
4) The bleeding silver solder (since I use too much, because I can't get it flow easily) has to be cleaned from the blade and guard faces using a brass scraper. Even then, I further compromise the original finish.
5) The flux tends to etch the blade finish, requiring even more finishing to make the blade back to original condition. (Yes, I rinse in a base fluid to neutralize the acid)
I think it's time for JB weld or similar metal epoxies. Good thing I'm not a welder.
Mike L.
Mike L.
