Thanks daizee. I have my momentsSweet mod, Tank!
Anybody remember my first one?
This is just roughed/sawed out.
Tons of work still.
I might not get much done till next week, but I wanna send out for hea-treating soon with some more stuff.
Not sure I agree with it.....but I'm flipping my handle configuration around, opposite of my first one. Seems like that was a concern of some.
I'll get to try out both versions for a good comparison.
I'm also toying around with the idea of holes instead of slots?
I think it might be stronger without the straining of the metal in the slots, idk?
Easier to make too, unless I get a bunch lasered.....
I'd want to talk upstairs before I sold any.
This one is Thicker, and AEB-L. Should be a tank. Great to be left outside in the backyard by the grill or fire pit.
I wouldn't even know how to do that, Smoke signals? Lol.
I have access to a machine shop......Whee!!
How thick is the AEB-L?
Slots? In the handle? Those are for balance, presumably. With all that blade I think you'd want as much weight in the handle as possible. But in either case, drilling holes is easier unless you have a milling machine.
Sub knife?Oh, a SPATULA!!
Yeah, gonna have to put that bad boy on a diet and decide how hard you want it.
AEB-L doesn't have super high heat tolerance, but you're not making a knife blade, so I think you're going to end up with a SUPER tough tool at sub-knife-hardness. Sounds like a good plan to me!
This was my first.... I Love it!Oh, a SPATULA!!
That's a good idea adding weight.
I agree, I'll need to take a fair amount out.....150 is garden hatchet/weeding tool territory.
you'll need 1/8 or 3/16" slots 1/8" apart to drop the weight significantly
Thank..... All that sounds good.375F temper puts AEB-L at ~61Rc.
Just speculating, but I'd expect your "edge" to get up to 500F on the surface, but only the VERY surface/edge. So it won't hold a KNIFE edge very well (where it gets hot), but should be fine for everything else. If you won't need an actual knife edge, I think anything from 45-58Rc would be great for a brutal spatula. More than 58 in AEB-L doesn't buy you anything except brittleness (in this application), IMO. Though AEB-L is ridiculously tough as hardened steels go anyway. There may be a toughness peak in AEB-L in the 60-61 range. Hotter/softer may be less tough (local minimum), but I'd have to go look at Larrin's charts.
Coals will be VERY hot, not the air temp or grill-grate temp. But with that mass it won't absorb heat TOO fast.
Another thing to note: The higher temps the steel reaches in temper or in use, the less stain-resistant it will be. So if you'll care about that real hard, keep the edge that gets hottest dry.
In any case, it's gonna be awesome.
Each prototype has a different handle orientation.The slots are really cool. I don't know why.
Maybe because I don't have a way of doing that in my shop.
What's your thinking on the handle orientation? It looks upside-down at first glance, but clearly you made that decision on purpose.
