- Jun 12, 2018
Hi all,
I am trying to make a 2x72 belt grinder, and have run into a problem.
I am getting significant wobble/vibration at certain frequencies.
To preface, the parts are as follows;
1) wheel kit from Oregon Blade maker - https://originblademaker.com/product/belt-grinder-2x72-wheel-set-24mm-bore-nylon/
2) Baldor 31115 motor (new) 3 phase, 1HP
3) Teco/Westinghouse L510 120v single phase to 240v 3-phase converter/VFD
I spent significant time messing with the alignment of all the wheels in the same plane, and especially the idler wheel on spring loaded riser - but nothing seemed to shake to vibrations.
I turned the drive wheel which was significantly out of round on my lathe, with little or no effect.
I measured the motor shaft run-out using a mag mount 0.005" mic, and there is definitely a 0.005 "hump" detectable in the shaft.
I also am getting pretty noticeable side-side belt wobble - which seems to always be present regardless of which belt (tried 5 of them)
So I am curious as to your suggested steps to troubleshoot and identify the real problem here.
My first inclination is to order a new motor due to the measured run-out and that messing with all the other wheels and everything seemingly in plane hasn't worked. But that is obviously a very expensive proposition.
Hoping someone has some ideas or at least a confirmation that I should give up on that motor.
is 1/2 thou on a 5/8" shaft a lot ?
