You are so right Fred. I have noticed stuttering if I put the edge/spine into the belt perpendicular and tilted a little upwards at the contact point, so if I am hogging metal off at a perpenticular angle I make sure either to be either at 90 degrees or tilted slightly down.
As far as sharpening on a slack belt edge leading... I do this a lot as well have have never noticed any issues. Question: when you do a full convex to zero (on a slack belt) how do you finish it? Edge trailing? curious...
Josh,
I have a real aversion to slack belt convex edges. This is why: when an edge is placed against a slack belt, the belt gives, with the apex of the cutting edge being the pressure point. Depending on the pressure applied, the belt is moving across the apex at an uncontrolled projection, which to my mind, "Pushes" the apex to the opposite side of the blade. Change sides and it happens on this side as well. The apex moves one way then the other. Its thinning the burr @ the same time the result is a very thin burr thats easy to remove.
The slack belt technique produces a sharp edge, I agree. I just think there are other, better options that exhibit improved cutting characteristics. This type of edge is hard to reproduce on anything other than a belt machine. This is how the mouse pad came into use which has the same effect on the apex. If you think about this technique using a different scenario: suspend the belt between two supports by its ends, now place the blade on this "slack" belt and move the blade along the belt. The belt always angles away from the apex as the edge moves along it.
I'm a flat edge kind of guy
its no doubt because of the Bubble Jig and ERU that I manufacture and use constantly. But I do produce a convex edge in a manner of speaking. If its done on a 2 x 72 belt machine, I grind a "flat" edge on the platen, using a Bubble Jig to control the angle, say 15 dps. Once the burr is created and ready to be removed, I change the angle of approach, making it more acute and in the process the shoulders are rounded making the geometry more efficient. When I sharpen on our wet VS machine, using a Bubble Jig its easy to achieve the rounded shoulders but with a "flat" apex. I love sharpening knives, a little weird me thinks
