- Sep 23, 2014
Jerry Fisk does that , raise burr on beltsander, remove with a Norton India^this .
No need to use machine power where some quick manual power on belt or stone will do!
The Knifegrinders.au & BESS Forum guys have studied deburring more than anyone. Tons of info on those sites. Knifegrinders has written a whole book just on deburring.I'm not making a lot of progress on deburring on belts so far. I've tried my medium scotch brite quite a bit. It makes a difference. Seems to lift the burr off of the edge. But I can't get that belt to remove the burr. Increasing the angle seems to round off the edge badly.
Bare leather, rough side out, doesn't do a lot besides flip the burr. Smooth leather, with green compound seems to work decently, if not fully. But it also polishes the edge quite a lot. I've just ordered a "very fine" scotch brite belt, which I hope will be better at deburring.
I'm currently doing everything edge trailing. I'm considering doing some edge leading. But this would require me to either turn the machine around, or to wire a reversing switch into the motor.
If I'm going to reverse the motor, I kinda want to install a DC motor with variable speed. That way I can go nice and slow, and hopefully remove the burr in a controlled fashion. On the other hand, I don't want to waste my money if that's the wrong approach.
Should I be using a harder device like a paper wheel or scotchbrite wheel, on a buffer?
It's interesting to me that the major challenge here is NOT grinding the edge. That's actually pretty straight forward. It's deburring that's the hard part.
Brian.
Thanks Brian - is there a reason you only want to deburr on the grinder? I think you could do it on a stone pretty quickly and one less belt to change.I've been on the BESS forum for a short while. Definitely some interesting information over there. I've seen the Knife Grinder's book on deburring and am considering buying it.
Thank you for reminding me.
Brian.
"Parallel"... don't you mean perpendicular? As in, knife held vertically, edge-downward? The trouble with this type of grinding is that it is hard to reliably hold that angle relative to the ground. you'd be better off with a fixture that holds the knife secure at the appropriate angle as it approaches the grinding surface at its angle, like the edge-jig on a Tormek.
This is REALLY making me want the BESS tester. I already use consistent sheets of newsprint to test all my sharpening, but the tester takes measurement to a whole new levelThe leather with compound seems to work well in many forms: flat strops, leather wheels, and leather belts too. My leather belt on the sander works fairly well with compound. The "problem" is that it polishes the edge more than I would like. Which is why his blade so cleanly shaves hair. I would bet it's rather smooth and not very toothy.
This morning I used my new Very Fine and Super Fine scotch brite belts on a kitchen knife as a deburring step. The VF works pretty well, followed by bare leather. Lots of tooth, but a little burr remaining. Switching to the SF, I removed more burr. Then leather and it seemed to be all gone. But so was most of the tooth. The resulting edge was pretty good. BESS 185, 190 (two tests). Slices phonebook quite well. This is another steel that seems to hold on to the burr a lot. The original edge from VF + bare leather was BESS 200. Not a lot of difference on this particular blade.
Brian.
The B model seems perfect for regular use. B bgentry - I read your thread over at the BESS forum too. Great info thereIt's a bit of an indulgence for me. While it's cheap in the world of testers, it's "expensive" compared to most sharpening equipment. I think it cost more than all of my DMT 8" plates put together.
On the other hand, I don't have a lot of other hobbies. I have a few, but don't spend much money on any of them. Someone made a strong case to me that being able to measure my results with an actual number would improve my sharpening. Not so much so I can "score" the end result. More that I could test after making changes and have an actual number that told me if I had made the edge better or worse. So far I think it's pretty valuable.
Oh, and if you talk to Mike (the inventor) he will tell you that his middle model (the "B" version) is all anyone needs and is the best overall combination of resolution and value. He makes the "A" version for those that want more resolution, but he absolutely does not recommend it. The 5 gram resolution of the B is already borderline ridiculous for knife sharpness testing.
Brian.
thanks for the review! I'd really like to try one of these. It seems like people either love them or hate them. They can't be beat for the price, especially if you already own a grinder.
How would you compare them to using paper wheels on a similar grinder/motor?
Mark the sides of the wheels with a protractor. And you will find by holding the blade straight (parallel to the floor) you will find the appropriate spot on the wheel. Practice with an old hacksaw blade first. I've used belts, ko worksharp and find the paper wheel to be superior and more efficient. If you haven't I would read the sticky. There's a load of good info there.I really don't know, I haven't used my paper wheels yet. I have serious misgivings about my ability to do repeatable work on the wheels without a ton of setup per knife or tool. I had considerable trouble getting my wet wheel grinder to do repeatable precision work and the paper wheels will have some of the same issues doing accurate angles and different curvatures with a guide on a wheel.
I do not like to use powered sharpening without a pretty good guide, although I'm sure the paper wheels work well freehand (probably ideal for this), esp if only being used to remove the burr. I'll be taking another look at them after I get all the kinks worked out.
The leather belt on this unit is working better than I expected, went back and redid the plane iron and chisel and was able to hit original angles perfectly, shrunk the amount of camber on the plane iron, finished the same way. One of the techs was handling the plane iron blade after I left last night and checking it on his thumbnail almost put it through.
Honestly it isn't a huge amount faster than doing them by hand except for the initial bevel setting, but I could do a set of them, one after the other and by hand I'd be getting worn out after two or three.
As for the Multitool, if you're willing to finesse it and bend a few bits to fit properly, it seems like a pretty rugged unit. Again, if you're going to be grinding blanks or doing serious regrinds you'd need to put in some added support on the arm, as it does flex under pressure. Overall pretty solid little unit, runs quiet enough that hearing protection is probably optional. The variable speed 8" grinder is a nice option. I modified my wet wheel guides to work on the horizontal belt, combined with the knife guides from my 1x30 and a benchstone holder for the platen, it has all the functionality I could want except for a waterstone bath.
Will get back to you on the paper wheels for finishing. It is unlikely I will ever use the grit wheel.
Thanks for the reply. I feel the same way about belts/stones vs. wheels. I know there are lots of ways to help with the geometry of a wheel, but its hard for me to get my head around it vs. the flat plane of a belt or stone.
Not pushing you. But mount your wheels running away from you. This way your at the top of the wheels. I think it's an easier way. But that's everyone's choice. Check that sticky. And good luck!I spent a lot of time setting up to be able to go from belt to stone and back if necessary. Introducing a wheel changes everything. Freehand for finish work is a possibility, but making multiple passes on a wheel and picking it up at the exact same angle and grind path, esp around the belly is way beyond my skill level.
Will take another look at the sticky, had many conversations w/ Richard J back in the day and made my own 6" wheel but was never able to get comfortable with it. Did manage to make a few sawzall blades into sharp utility knives, but the cosmetics were so far out of spec I could never have used it for commercial work.
