Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Just as a point of reference, a mile is 5280 feet, so it would take a little less than 2 minutes for a mile of belt to pass under your blade as you grind...
Tell you what, I just got a batterey powered, rather portable, hand held laser tachometer on the auction site. It shoots a little laser dot on whatever you want. You stick on a piece of reflective tape and it gives you an LED rpm reading.
You could put a piece of tape on the belt and it would tell you RPMs and multiply by 6 feet for SFM.
Or stick it on the pulley itself and multiply by diameter of the pulley.
Shoot what ever you want and figure accordingly.
http://cgi.ebay.com/ebaymotors/New-...318QQhashZitem350079669166QQitemZ350079669166
Right on Deker!!
Even if you don't use a 4" drive wheel...keep it in mind to simplify your shop math. I love Pie!! YUM!...but in this case Pie is not a tasty snack that brings ants into the shop to clean up the crumbs...."Pie" is special math thing involved with circles...it's actually spelled Pi and it is roughly the number 3.
The 4" drive wheel X Pi is 4" x 3 = 12".....= 1 foot.
I think anyone who does that much math for fun has holes in his head. But, with deker, that is redundant.
Just for funand since you asked for it)
Hand sanding is done at about .00006 kilometers per second
Your average belt grinder runs about .02 kilometers per second.
If you are standing in Ecuador you are moving at .5 kilometers per second....as the earth spins around its axis.
If you look up from there ,you will notice that you are also moving at 30 kilometers per second as you circle the sun.
If you look at the stars you will notice that you are rotating through the Milky Way Galaxy at 220 kilometers per second.
And if you look at the cosmic horizon, you will notice that our galaxy is moving through the universe at 390 kilometers per sec, as the universe expands ( this is called peculiar velocity...one of my favorite technical names).
So.... The pulley ratio on your grinder is relatively not changing things much at all, on a cosmic scale.
Stacy
