- Jun 21, 2020
So the pic below is my recently modified grinder. You can see the flat piece of steel bolted on to extend the platen out. I did this so I can grind freehand and be able to look down the platen as I grind. Before I extended that out the belt ran nearly straight from the small wheel at the top to the 10" wheel at the bottom, obviously not allowing me to look down the platen without grinding my face off.
My problem is that now I can't keep a belt on for the life of me. It shoots to one side or the other, falling off both wheels and being useless. The tracking adjustment only tightens or loosens the belt instead of adjusting the tracking. I've also tried loosening the two set screws under the tension spring to pivot the top wheel left or right. That didn't work as I wasn't able to make small enough adjustments to be beneficial.
I also should note that when I check the tracking by hand it seems that it will work fine, but once I turn the machine on- off goes my belt.
Any ideas on what to do?
