Happens on the Spyderco forum all the time.Curious how an Internet forum seems to attempt a redesign and re-engineer a model, based on what, exactly?
Well, we don't know. It could be they just used the puukko heat treatment on a dramatically thinner blade and assumed it would work just as good.Maybe Benchmade wanted the hardness lower...Or it's just more steel-of-the-week nonsense and marketing ploys...
Yup, it’s all speculation and that’s why @Benchmade needs to chime in.Well, we don't know. It could be they just used the puukko heat treatment on a dramatically thinner blade and assumed it would work just as good.
Maybe it's flavor of the week.
Maybe it costs more to create a new profile for 3v and run the Puukkos separately through the ht process than the folders.
Maybe they didn't test them as well as they thought or had some random numskull test them and get poor feedback from them.
Maybe all the above. Maybe something not listed.
I know that @DeadboxHero tested the puukoo then reground it thinner and tested it again and it showed to be way to rolley Polley imho. He's got vids on his yt if you want to watch them in detail with his comments. I'll attempt to embed them later.
I personally think they should listen to what the customers want.
Do you need a knife A FOLDER that you can bend the blade 90 degrees? Nope. Use a fixed blade if you are going to be that hard on a knife. The handle would long break before the blade.
The 2 hardness ranges I use for 3V are 59/60 (59.5 best case) and 61 HRC with a low temper protocol By Peters.
The higher hardness rating will reduce toughness VERY slightly, but increase edge stability (support thinner edge) and boost corrosion resistance. 59/60 is used for maximum toughness. I know 58 is tougher but I've been using this for a long time. The results have been excellent.
The hardness rating on 55-58 is insane. That is way way too soft. You give up so much edge holding. Even if they ran the steel at 59 or 60 that would be more than tough enough as a folder. As long as HT is done correctly. Users would benefit from increased edge holding and less rolling.
Just my 2 cents.
Here's the primary source, page 92 of Benchmade's 2019 catalog: https://www.benchmade.com/media/forms/2019_Benchmade_Catalog.pdf
Yea the people who make those charts are not smart. It happens alot.Wtf at the major differences between 20cv and m390? What baboon made this chart? And 440c having better edge holding than damasteel and 3v hahaha
Did you post anything on Benchmade's subforum?Yup, it’s all speculation and that’s why @Benchmade needs to chime in.
That’s like me buying a Honda Civic being promised 36MPG and once I start driving it I’m only getting 25MPG. If I go back to the dealership and complain am I trying to overstep all of the engineers? I don’t think so. I think I’m asking to get what I thought I was buying.
Am I missing something?
Well, you are kind of missing something...
Benchmade promised you a certain hardness, and they delivered it. You just happen to be dissatisfied with it.
Be closer to say it would be like Honda said "Here is a Civic, it'll get 25MPG", and you stating that with a couple simple tweaks that the actual petroleum supplier recommends, they can get 36MPG. So why the hell aren't they giving us a 36MPG vehicle for our money?
I see where you are going with this, and it's a valid point. I am sincerely interested in why BM selected the hardness as well.
It wouldn't keep me from buying this piece. The hardness would be fine for my uses for such a knife.
No, I’ll be fully transparent. I do not frequent BF outside of the traditional and sales sections. The reason for that was made clear from the guy with the “idiot” comment. I never intended to bring this over here. The OP created this dialog on BF.Did you post anything on Benchmade's subforum?
That's fine, but if you actually want an answer you should post it on their forum rather than tag their moderator. They have a design engineer for Benchmade post frequently in their own forum and he would probably be the one who would answer for this.No, I’ll be fully transparent. I do not frequent BF outside of the traditional and sales sections. The reason for that was made clear from the guy with the “idiot” comment. I never intended to bring this over here. The OP created this dialog on BF.
I have emailed them, tagged them in numerous places, commented on their own IG posts, replied to BM’s posts that I’ve been tagged to, other people have DM’d them, I’ve seen screenshots of them acknowledging they know about this, tagged them here 4-5 times. I’m not hiding this in any way.
I literally have a screenshot of them saying they know and are about to respond. I’m the customer. I don’t have to chase them down. Especially when I know for 100% that they know.That's fine, but if you actually want an answer you should post it on their forum rather than tag their moderator. They have a design engineer for Benchmade post frequently in their own forum and he would probably be the one who would answer for this.
if you go to the benchmade company forum you can talk to the gentleman who designed both the bugout and the bailout. jason is the primary moderator over there. he may have more insight into why it was done the way it was.
