- Aug 22, 2009
I am thinking about getting the BENCHMADE 585 MINI BARRAGE, any reviews on this knife. I noticed the handle material was a valox material..what is that?
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
valox is a plastic like material, they yse it most notably on the griptilian series. It does feel rather cheap but I haven't noticed any performance issues with it thus far
I think Valox is just a brand of plastic. The kind they use in the Grips, if I am correct is "Noryl GTX."
And you would be quite correct as usual, THG. :thumbup:
AFAIK Noryl GTX only comes in black. All other colors of the grip are either coated Noryl GTX or Valox.
There was a discussion about this few years back on BM forum.
I thought it was always assisted opening?
My brand new mini-barrage is back to benchmade for the second time in a month for vertical blade play. They sent it back to me and my vertical play was still therehopefully when i get it back in a couple weeks it will be fine.
I own two other benchmades and they are both perfect so i'm sure this was just a fluke.
As for the knife when i didn't notice the problem with it all i can say is it's a fun knife. the assisted opening has a good kick to it which i love. the handles are a little slick and there's no jimping on it so if you are going to do any tasks that require a tight grip you might want to look elsewhere. it's just fine for EDC use.
If you want a benchmade of the same size without assisted opening they have a few to choose from, mini-bone collector, mini-griptillian comes in 4 different blade shapes, mini-presidio
Did the knife with the blade play have a black coated blade by any chance?
as a matter of fact it does. is there some issue with the coating blades and blade play?
It seems to me, that the Black coating would eventually start to wear off, and create a gap between the blade...Creating blade play...I think ?
Those companies you mentioned asked/paid to have a subforum on BF.Since you guys are talking Benchmade Knives here, a quick question.
I'm new here at "Blade Forums" and have noticed there is no section/sub-section for Benchmande Knives as there are for Spyderco, SOG, etc.. Am I just not seeing it?
Benchmade has it's own forum on their website. Cross forum links are not allowed here, but you can google it.
The AXIS lock is pretty simple. The only way there can be vertical blade play is if the lock bar is not all the way forward. The black coating is a little rough at first and can cause the lock bar to hang up some and not go all the way forward. If you had used it for a week or two and let it wear in and smooth out it would have gone away. Some of the coated blades I have seen have the coating removed on the tang but I have seen some that there is still some coating left on the tang lock ramp.
Even if it was uncoated, they can still be a little rough when new and need to be used some to smooth out. Was the play very slight, like maybe a half mm at the tip? Even with a little blade play, an AXIS lock is not going to fail because of it and there is usually very little and it's not like a lock back where the blade can move with pressure.
I would be willing to bet that most people would never know there is horizontal or vertical blade play unless they compulsively tug at the blade looking for it. I have knives with a little play and it has never been noticeable in use.
