Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
I was in your boat as well but I have found that frog lube gets a little gummy in the pivot and slows down the action after a bit. That is why I switched to blue lube for my pivots.I wanted an all around CLP safe for food use so I can put a tiny drop on the pivot and after heating the blade a little layer of lube on the blade.
Didn’t want to mess around with multiple products price wise and just sorta an inconvenience.
Think I’ll go with frog lube for all my needs.
Thanks!
What kind of climate do you live in if I may ask?I was in your boat as well but I have found that frog lube gets a little gummy in the pivot and slows down the action after a bit. That is why I switched to blue lube for my pivots.
nano oil is snake oil for sure.South Carolina. Its gets pretty hot and muggy down here in the summer for sure.
I've actually tested several lubes included the infamous Nano-Oil and found blue lube to be superior for smooth action in the long run without any gumminess. I was actually shocked at how much better blue lube performed over nano oil.
