Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
Just got this in, so here's some initial thoughts regarding this folder.
In the looks department it has some bling, not heavy but enough to make you take a second look, that along with the shapely flow of the handle and how the g10 scale meets up at a point with the bolster, nice touch there. Also please note that the presentation side (for right handers that is) you see that the screw heads are on the clip side while the smooth ends are on the presentation side, adding to that finished look.
The blade, she's big and bold to be sure, my pet peeve has always been the sharpening notch before the edge, here they set it at an angle so material that does fall into there will slide up and out, better than just a straight up and down sharp corner. The finish of the blade appears on the rough side, not a stonewash finish, but it's in the Hunt series of their new line so it's meant as a field folder, even if she's cute. The bevels are fairly even and quite toothy on arrival, I am holding off on sharpening this 4" long S30v blade until it needs it. Measured at the top of the current edge bevel is about .025" not super thin but fairly thin on such a large blade.
The Axis lock is the familiar lock, works flawless on this with it's bronze washers, no ball bearings in there, but it's smooth opening, solid lockup and easy to close. For those that are concerned with such things, the blade is nicely centered when closed.
The bolster is aluminum, Ti would have been nicer but probably unnecessary as the frame takes the brunt of the work of the folder, but it's nice to have a bolster on there instead of all g10 scale. The handle measure about 5 3/8" long, pretty long with plenty of ways to grip, as there isn't any heavy finger grooves to prevent that, but the guard serves well in keeping digits from being separated from your palm.
This has an orange g10 back spacer, some may dislike it, others will love it, myself, I can take it or leave it as my hand covers it in use I don't see it so it matters not to me. The way it's machined doesn't give any hotspots that I can tell so far, not sure just why it has a sprocket looking teeth on there but again, it isn't in the way for me. The g10 scales are smooth, a little more texture would have been handy, but might have taken away from some comfort/feel that the knife has.
The split arrow clip works well, I am looking to get one of the deep pocket carry clips in, but this works great. I've added one of my diamond knot paracord lanyards on there, the celtic bead slides up to your wrist to act as a keeper during use, very secure.
Here are some images taken tonight;
Nice swedge on there too, many compare this to the Buck 110, I can see it but it's still it's own style too.
and a shot showing it along side my Case mini copperhead, good companion folder to go with it's larger friend
It's knocked out the folder that was taking up room in my right front pocket, for how long? that's hard to say as I do go through knives far too quickly, hoping this one sticks around a while.
G2
G2
