CPM 3v is quite tough. i don't think that will be such an issue but we will see
Yeah, but normally 58-60 is where the steel manufacturer suggests is best for a knife. 62 might be a bit much....
the reasons people buy the Benchmade and not the traditional leukus and puukkos are because
1: the real thing is usually expensive. (however, you do pay for quality)
2: the real thing may have "outdated" materials (not always the case)
3: the real thing doesn't come with a lifesharp warranty
4: brand loyalty
5: most traditional leukus and puukkos don't have a full tang
6: not enough research
Expensive? No, the Benchmade is more expensive than most decent factory made Finnish knives.
A handmade puuko would be no more expensive than any other handmade knife.
Outdated materials? What does that mean? 3V isn't exactly a new steel, and there are better steels if you want a long lasting edge. The handle materials used by Finnish makers are just as good as any other maker, sometimes better, and stacked birch bark is better than any modern non-slip handles if done properly.
What good is a "Lifesharp warranty" (whatever that is) if you are actually using the knife for what it was intended to do? If you are camping in Alaska what do you do, send it in for sharpening while you use a more useful knife that you can actually sharpen yourself with an Norton stone? What advantage is that, except for those who never actually use the knife for anything except cutting veggies in the kitchen? If you can't sharpen your own knife, what does that say about your "bushcraft skills"....
Brand loyalty is silly. If you need a knife you can depend on, you don't buy it because you like the name, you buy it because it does what its supposed to do without issues.
Most traditional puukkot and leukut have tangs that extent all the way through the handle. Not full slabs but not just a blade stuck into a handle either. I have a stag handled Randall Model 1 that doesn't have a full tang. Lots of Webster Marbles knives had stick tangs. Didn't bother anyone for decades and it doesn't bother me....
Not enough research.....yup.....
