Benchmade screw sizes?
Just put my mini-Stryker back together after doing some major cosmetic surgery. All except for the clip that is. I decided that I needed slightly thicker scales than the original G-10. Now the clip screws are not long enough to thread back into the liner. Thinning the handles is not an option as they are very comfortable the way they are. Does anyone know what size these little devils are and where I can get longer ones? Please don't tell me they are some special BM item. Would like to replace them with stainless anyway, as they are the only black left on the knife.
Well, I don't know for sure, but it wouldn't surprise me if they are a special off-size.
Benchmade has several automated screw-making machines and they make many of the screws, washer, spacers, pins and other similar parts themselves. Why? Well, with that capacity in-house, their designers don't have to confine themselves to standard parts. This enables them to do things that others can't.
If you're ordering all of your parts from the same catalogs that everyone else does, then don't be surprised if your product looks a lot like everyone else's. If you want to make unique products, you often have to start with unique parts.
Now, of course, Benchmade doesn't jump to custom parts for every little piece just because they can. Even if you own the machine, custom-made parts are never going to be as cheap as standard parts. Besides, the machines have limited capacity. You don't want to overflow that capacity making custom parts to use where standard parts would do.
But, it is possible that the part you need is a special part. Sorry.
BTW, Benchmade also uses a lot of Metric sizes. So, you might check that out too.
Failing that, take 'em to a local machine shop and ask 'em to measure them for you.
Chuck
Balisongs -- because it don't mean a thing if it ain't got that swing!
http://www.balisongcollector.com
How much longer do they need to be (how much did you thicken the scales?)? If it's just a short distance, you might consider making a cutout to accept the mounting plate of the clip (so it is flush with the handle surface, instead of on top).
--JB
e_utopia@hotmail.com
e_utopia, that is what I have planned if I cannot get longer screws. The clip would have to be recessed only the thickness of the liner (approx. .060). My Dremel and I do not excel at precision milling however, and it will look cleaner with the less work I have to do to it
Hey Blademan, you can get a little router attachment for your Dremel that will make work like that a snap. You just have to make a positioning jig out of pine or something so you have a level surface to work with.
Jake
Yeah, use the Dremel to remove the center, but stay back from the edges. Clean up the edges properly with a sharp knife and a lot of paitience.
--JB
Cheap and readily available are screw sizing plates. These are metal plates with holes in them, some tapped with different thread pitches. It is easy to determine what a screw size is using one of these. They come in metric and inch dimensions. Most also contain non tapped holes for determining drill bit sizes. Walt
