Fixall
Brian
- Mar 26, 2018
I've put this off as long as I could, but it's time.
I'd like to pick up a benchtop mill next month. I know, I know... Buy once, cry once... Get the biggest mill you can... Get a used Bridgeport... Etc. I have a habit of purchasing equipment that greatly exceeds my needs though. Now, I won’t go as far to call it a bad habit, but I’d like to avoid that this time. My shop is running out of space, and my breaker box doesn't have room for another 220. Besides, if I was going to go that route, I'd probably just bite the bullet and pick up a Tormach 440.
I think I have it narrowed down to either the Little Machine Shop 6550, or the Precision Matthews PM-25MV. The LMS-6550 is about $700 cheaper. I think the LMS-6550 would be able to handle everything I'd need out of it, but I was hoping for some advice. I had also looked at the PM-727V, but with the most recent price increase, it's almost $4,000 now. Tough pill to swallow.
If I go with the LMS-6550 or the PM-25MV I will also be going with a 3-axis DRO, power feed, and probably a rotary table.
Here's what I'm hoping to do with the machine:
Immediate use - Quickly squaring a high volume of blocks (both composite, and wood) with a 2-inch face mill or fly cutter so they can be cut into scales on the band saw/table saw. Cutting slots in guards for fixed blades.
Future uses - Making pivot collars out of composites, and the corresponding pockets, relieving slip joint liners, cutting nail nicks, and reaming holes.
Other than milling pockets, I think all of that can be considered fairly light use?
Here's how the machines break down:
Little Machine Shop LMS-6550
Based on the Sieg SX2.7 with some upgrades
$2,400
245lbs
19.7" x 5.5" x 11.6" of travel
1 horsepower
.6" end mill capacity
2" face mill capacity
.8" drilling capacity
2.8" quill travel
belt driven head
100 - 2500rpm spindle speed
R8 spindle taper
$3,100
275lbs
19" x 7" x 13" of travel
1 horsepower
.75" end mill capacity
2.5" face mill capacity
1" drilling capacity
2" quill travel
Belt driven head
50 - 2500rpm spindle speed
R8 spindle taper
If someone can make a REALLY convincing case for the Precision Matthews PM-727V, I might consider it... I really don't think I want to deal with another 500 pound machine though.
$3,600
475lbs
15" x 8.5" x 16" of travel
1.5hp
1" end mill capacity
3" face mill capacity
1.25" drilling capacity
3" quill travel
hardened, ground steel gear driven head
40 - 3000rpm spindle speed
R8 spindle taper
$2,400
245lbs
1 horsepower
2.8" quill travel
belt driven head
R8 spindle taper
$3,100
275lbs
1 horsepower
2" quill travel
Belt driven head
R8 spindle taper
$3,600
475lbs
1.5hp
3" quill travel
R8 spindle taper
