Well I'm not going for my JS anytime soon, a guy can dream right
I also went ahead and did a few 90-bend tests this winter to see if my blades could pull it off....LOL
I did a few tests, I learned a few new things.
I learned that clay-coating my 52100 didnt work at all, as far as being able to keep my blade from fully hardening. Im not sure why yet, but the one blade I tried that on sure didnt pass this test at all..LOL (I wish I would have some video of that test and the look I had on my face when she snapped)
I learned that tempering is a bit more important than I have always thought.
I ended up bumping my oven temp up higher to 450. (However this might be only because my kitchen oven has wide mood swings)
And I learned not to overheat my steel before the quench. (I have always had trouble pulling the trigger and quenching)
The things that have changed with the way I do knife now, is that I pay close attention to the Normalizing and Annealing stages.
With the last few blades I have added a 2nd Normalizing just to make sure it takes.
I have always Annealed by allowing the blade to cool inside the forge, but I'm thinking now that this might not work so well if the temp of the shop is well below freezing.
I asked members of this forum for the amount time my steel needs to take to cool to be fully Annealed?, and the answers I received got me to believe that now Im not so sure the forge stays hot enough for long enough once it's turned off.
The one question/suggestion I have is about how you were able to bend the knife?
From a photo I saw in BLADE mag. I made a type of a clamp with a big bolt welded to the side of it. The bolt head allowed me to attach a socket wrench and so the force of pulling down was spread out more even.
Also, I think doing such tests are great because they allow you to do the very same test as others.
Most of the other tests people talk about are hard to copy time and time again.
Even many cutting tests are hard to copy again to judge one knife against another.
(I have never been happy with my cutting tests, Am I testing the knife steel, or just my ability to sharpen an edge and be more carefull cutting this time over last time?)
But a test that is easy to reproduce in the future on other knives allows me to stay on a path where I end up with the knife I aim to have.
