I am interested to know which Buck 301 you fellows think is overall the best 301 ever made and why. This would include all those made in the early years by Schrade and Camillus. Personally, I like the 1988 transition model with the two backsprings and crinked sheepsfoot, the brass linings and the flat (or semi-hollow) ground blades. The only change I would made in that model would be to replace the BUCK shield with the traditional shield. I like all Buck 301's but would prefer that the following were characteristics of the newer ones were dropped altogether:
1. The change in the spey blade that allows its tip to be above the liner. I like the original spey blade.
2. The "comfort curve" grinding of the blolsters. That would be ok if they would grind the two corners on each end the same but they do not seem to be able to do that, especially on the end with the sheepsfoot blade. I do not think that the corners of the bolsters on any of the models were ever sharp enough to damage pockets.
3. The new shield is ok but would rather have the original one.
4. I realize that the three springs allow no crinking of the sheepsfoot but that seems to made the knife more bulky and a little less comfortable to hold and in the pocket.
Your comments and opinions please.
