Folks,
I need advice on the best tool/technique for splitting firewood while car camping.
Here's the typical situation... Firewood needs to be purchased locally due to pests and is sold pre-split to fireplace size; typically about 6" to 8" across. The campsites have no splitting blocks but typically have a nearby downed tree, exposed roots or large rocks laying around that can be used as a block sort of.
We like to burn our fires with 3" to 4" logs (small fire through the evening), which typically means we need to quarter the purchased wood. We also need to split off kindling from the quartered sections.
A few words on techniques I've tried... Full force splitting with a strong 2 handed swing and the wood standing vertical is a 2 person affair due to the lack of flat, stable foundations. We rely on a 2nd person to hold the wood with a stick while it's balanced on a downed log or root. I'd much rather find a solution that allowed me to split by myself.
I've batonned hatchets before but I understand that a) wood handled hatchets aren't designed for this (opens up the hole) and b) the only solid tang hatchet I have is an Estwing, which is horrible for splitting due to its full and high hollow grind.
I've used the Ray Mears style side splitting technique where by the hatchet and wood are held together and then struck against a log. This works fine for splitting off kindling from 3" - 4" logs but doesn't work for me for quartering 6" to 8" logs.
I would consider using the "golf swing" technique (See video here: http://www.equip2endure.com/WatchVideo.aspx?id=6e529ccbd73c40778aa35bfe5a9a8e31) but would want a longer handle I think.
I should emphasize that I don't need a splitting tool for any reason other other than splitting.
Tools I'm considering and seeking advice on...
0) Considering packing a 2' section of 2x8 lumber to serve as a portable splitting base. Thoughts?
1) Considering replacing the 14" handle on my 1.5lb hatchet to 18" for more swinging power when swinging 2 handed.
2) Considering a heavier splitting hatchet like the Estwing Fireside Friend or Fiskars 17" Splitting Axe.
3) Considering packing a full length axe but it would be more cumbersome to pack.
Thoughts and advice greatly appreciated.
