If you want both great ease of sharpening combined with stainless, yet don't ever expect to strike near rocks or metal objects, or to ever use it in -30 degrees Celcius temperatures, then 420J or HC.
If you don't care about stain resistance, and might occasionally strike near metal/rocks, or chop in serious freezing temperatures, then 5160.
440C does well, but is very hard to sharpen neatly with a crisp micro-bevel, and performs no better than the two above. It also varies a lot more, being very "temperamental" to temper. Some of it is the worst stuff out there... Never go for S30V, CPM 154 or even CPM-3V: The apex tends to make a tiny, nail-rubbing detectable lip under impact. INFI does not make these lips, but needs thick edges to otherwise stay straight... Below is all at the same level of use, with similar edge thicknesses:
420J above, CPM 3V below:
INFI above, 5160 below:
Gaston
