Im really wanting to try bow hunting for white tail this year. I havent shot a bow since I was a teenager and have very little knowledge about what im doing or what makes a descent bow. Need to buy one soon so can get a descent amount of practice in before I attempt this. Hoping there are some bow hunters here that can give me some advice on what to look for, name dropping brands and overall the best bow for the $.Would appreciate it. Thanks
PA hunting regulations are fairly reasonable and for the most part...well thought-out. I only have them to guide me so please bear with me.
My state requires a bow of any design to have at least a 35lb draw. Crossbows must be at least 125lb draw [NOTE: Crossbows and users are a different class of archery, not to be considered "bows" or Bowhunters" in this instance].
Bowhunters must use arrows equipped with broadheads having an outside diameter of at least 7/8-inch with no less than two cutting edges, which shall be in the same plane throughout the length of the cutting surface.
You should check your State/Provincial Hunting guidelines for these types of regulations.
Given all that, I use a PSE bow that's about 10 years old and is set at 68 lb draw [I hunt more than just whitetail...unsuccessfully I might add
]. I use Muzzy Trocar-tipped, 100gr. 3 blade broadheads.
http://www.cabelas.com/product/Hunt...d-blade/_/N-1100028/Ns-CATEGORY_SEQ_103855680
....on Cabela's Carbon Hunter with 4" AAE Vanes
http://www.cabelas.com/product/Cabe...r%3BSearch-All+Products&Ntt=carbon+hunter+aae
This is my 4th compound bow since Jr. High School and the one I liked most of all of them. It's also the 2nd cheapest of all 4...so don't lest the generalization of the cost of the bow dictates how it will perform. I had the most expensive bow I could afford at the time for about 1.5 years - an Oneida Eagle costing more than $900. I absolutely hated it. Other makers included Fred Bear and Indian. I would like to try a Matthew's myself....but don't have the cash for that venture at this time.
I absolutely suggest you find an archery dedicated outfitter....like a mom-and-pop shop that is dedicated to archery...or a Bass Pro [around here, Bass Pro have a dedicated archery shoppe]. There is such a thing as "this fits you, this doesn't" and they will help you determine that. They will also help tune that bow for you.
Given that you are hunting whitetail with it, I'd suggest anything in the 45-55 lb draw. IF you decide to hunt larger game, you'll want heavier poundage.
The only other suggestion is invest in a good pin sight and arrow rest.
Sights....you don't need a $200 sight to harvest an animal...but I would spend more than $50. I like my Trophy Ridge sight...paid like....$65 for it I think? Was about 4-5 years ago...
Rests.......Whisker Biscuits are nice but strip the vane/fletching off after a few passes. Pick one in your budget but one that keeps the shaft on the rest during light movement, yet drops away after you loose the arrow. I use a PSE Prowler drop away rest, which was around $75
one helpful hint - Get heavy therapy bands. Use them during your off-season to strengthen your chest and drawing arm. 5 mins a day every other day to keep your strong side primed for the draw. Also, practice often and in all kinds of weather. I suggest 2 [or more] dozen arrows. One dozen dedicated ONLY to whitetail hunting and the rest for practice/small game. Keep them ALL the tips at the same weight, this has served me well for decades.
