Best flux to use for forge weld...
I am a new knife maker I want to forge all my knives what is the best and cheapest flux to use for Forge welding I heard borax 20 mules is a good cheap flux to use
Yes, good old borax is the best. I forged blades, including damascus for several years, and only used borax as a flux. Works great.
Rich
Learn this quickly.
There are Very few exceptions to this rule, but "Best" and "Cheap" aren't bedfellows.
It just so happens that Borax will serve the purpose well enough (while being cheap enough) to be one of the "Very few" exceptions.
If your welding in a gasser you need a sacrificial bottom like kiln shelving, bubble alumina or mizzou. Flux will eat you liner up fast. Well you don't have to have it but it will save a lot of relining
Yours is actually a good question, we are used to use borax, but i don't know if there would be something better, regardless its availability and affordability.
In the past, blacksmiths have used sand... speaking of this, i wonder how differently it would affect the forge liners.
The flux needs to melt and dislodge surface metal oxides, while providing a barrier for oxidation, and it needs to work well at welding temperature
i start out with kerosene on a cold stack and then switchover to borax. The issue that some folks have with 20 Mule Team compared to anhydrous borax is that you have to use more and you make more of a mess.
You dont have to forge to make a knife
You don't have to make damascus to make a knife
read the stickies here
You can make a knife out of a steel bar and file it to shape
Check out all the WIP threads by Bruce Bump at Knife Dogs for damascus making
Check out Kykle Royer - Journey to .... for using kerosene
Check out Can damascus - or welding up all the seams on clean steel = no flux at all.
I have regular fire brick...will that work...
In a vertical blown forge, you can use broken up fire brick in the bottom and just dumped out when it gets nasty, assuming that one end of the forge can be removed. IIRC, Cliff Parker told me about that.
"...I have regular fire brick...will that work......"
Fire brick is a wide ranging term. The stuff you line home fireplaces with, the stuff that lines boilers, the stuff that lines kilns, the stuff in the bottom of woodstoves, and the stuff we use for forges are all called firebribck. They are all different, too. The firebrick we use is called hard firebrick, and is usually rated at 3000F. The ones we use for a forge floor are 1" thick by 4.5X9". There are two types of "soft" firebrick. One is a magnesia brick that is very soft and smooth, we don't use that a whole lot. The other is a tallow brick. 2.5X4.5X9" that looks crumbly. That is the brick often used to make whole forges and HT ovens. It can also be used to make temporary doors to block part of the front and/or back of an open end forge like the one shown in the OP's link.
I tried anhydrous borax, I dont think its worth extra effort. I made it myself, so that alone weighs in on the extra effort part.
Once the borax melts, it does not matter if it was anhydrous or not. Also, anhydrous needs to stored airtight.
I'll try and sum up fluxing and the very basic processes. Knowing what is going on helps know what to do.
Welding requires a good metal to metal contact. Anything between them that gets in the way makes the weld weak, or incomplete. Fluxing helps in keeping the oxygen away from the hot metal and also eats away existing oxides.
Borax - it creates a thick molten boron glass coating that protects the settl from the oxygen in the forge atmosphere. BTW, the forge burner should be balanced to have little excess. Twenty mule team and other regular borax are sodium tetraborate. It is boric acid that has reacted with sodium to make a salt. This is done in a watery mix, and the powder is dried from it. Some of the water is still tied to the boron salt crystal. This is called hydrated sodium tetraborate - AKA borax. You can bake it at 350F for several hours and drive out all the water and make anhydrous borax, but it will try and suck moisture from the air and re-hydrate. Since the water will be driven out in use when using as a welding flux, there is no real advantage to using anhydrous borax for blacksmiths/bladesmiths.
The borax is applied to the clean and wired/welded together bilet when it is just getting to red heat, heated a bit more into the orange range and re-applied, and then applied again at the yellow welding range. It should coat and run all over the billet. One of the things that borax does to aid welding is eat away any oxides because it becomes something like a molten hot acid.
Putting a large metal baking pan under the billet when shaking the borax on saves the excess for later use. A container with holes in the top, like a parmesan cheese jar works great. You don't want too much flux, because it will just run off on the forge floor and spray around the room like flaming meteors when you set the weld, but assure the billet is fully covered when at welding heat. Make sure the weld blows start from one end and from the center out or you won't expel all the borax from the layers. Trapped borax will create a weld flaw that cannot be repaired. This is probably the major drawback to new smiths. The flaming meteors headed toward your crotch ( and everything within 10 feet) are the other problem.
Abrasives and shields - Many ancient techniques use things like ash, wrapping in paper, charcoal powder, fine fluorite or quartz sand, and fine clays in a slurry to coat the metal and aid welding. These still have some advocates today, but for the most, they have been replaced by better equipment and materials.
Hydro-carbon welding
- This is a newer and popular method for production damascus welders. The billet is kept in a bucket of some hydro-carbon after assembly to keep all oxygen from touching the surfaces. Since it will seep into the tiniest space by capillary action, it covers and protects all the billet. Kerosene and brake cleaner type fluids are the most popular fluids. When ready to do the weld, the billet is removed from the bucket ( which is covered securely), drained a moment, and put in the forge. The fluid burns off leaving behind - CARBON - just what we really want in the space between the welds. It will slightly raise the carbon content in the weld surfaces (making the line etch slightly darker) and it also will eat up any oxygen around. From the initial setting of the weld throughout the next heats, not allowing the billet to cool below black will assure no oxides form between the layers, all yielding a very securely welded billet. When folding and drawing a billet out, a wire brush is used before and after each draw. The billet is hot cut at the end of a heat, brushed off, re-heated, brushed again, folded, and welded. If all is done at a red heat or above, the use ofa small amount of borax when folding is all that is needed.
Dry Welding
The newer and gaining in popularity method is dry welding. It is welding up a billet in a way that allows no oxygen inside the billet at all. This is done by cleaning the bars, stacking them and clamping tight in a vise, and welding up all the seams. Modern affordable TIG and MIG welders have made this a home shop possibility today. Once fully welded shut, the billet is processes as any other damascus billet. This Is a very good system for doing a long san-mai billet for a large knife or sword.
If you are welding a billet with hydrocarbon or borax flux, you start with a clamped billet and then welding just the corners or ends together, and maybe a stripe down the middle.
Canister Welding
Placing the stacked billet in a square tube or box that has the ends welded shut is the other common way to dry weld. The bars are cut to snugly fit the tube or box, stacked full, and the end is welded shut. Some put a tiny hole in a corner to let gases escape, but from what I have heard, most just want it full and airtight. There are all sorts of techniques like wrapping the billet in a sheet of paper, coating the inside of the tube/box with whiteout or titanium white paint, and spraying the inside with WD-40. These are for a more detailed tutorial, but are part of the process.
Once sealed, the billet can sit around until you are ready to heat it to welding temp and take it to the power hammer or press. Once fully welded solid ( you will hear and feel the difference), the canister/box is cut or ground away, and the billet is reduced, manipulated, folded, etc.as normal.
Powder damascus
As part of the canister method, finely powdered steel is often added to the steel in the cannister. This fills the space to 100% and makes for a pattern impossible otherwise.
This is the method for mosaic damascus."Junk Box damascus", made from old drill bits, barbed wire, motorcycle chain, ball bearings, springs, and any other steel thing you can think of is made this way. A really cool damascus often called "bacteria" is made with various size small ball bearings and short broken pieces of old drill bits ( use both the solid part and the twist part). The pattern ends up as spirals, rods, and circles.
Lots of good information in that post!
The only thing I'll add is if you're using brake cleaner, make sure it's the non chlorinated type. Chlorinated brake cleaner produces phosgene gas when heated, and has killed several welders who used it to degrease before Tig welding
I am not sure if theses accurate, but I was told that when hydrocarbon "fluxing", you need handle the billet gently once it forms the carbon layers because they are delicate and can "crack" and expose parts of the steel to oxygen.
Geoff is 100% correct about the dangers of brake cleaner. Phosgene gas is no joke. I'd opt for kerosene before ANY brake cleaner. Phosgene gas can be deadly at levels as low as 2ppm.
Yes, I recommend kerosene, too. I only mentioned the cleaners because they are commonly used. As with any burned stuff, proper ventilation and airflow are important.
A not-so-funny story about burning industrial stuff -
Back when I worked for Ford, the Norfolk Assembly plant produced a lot of trash and other waste - most of it either a paper product or some sort of metal. They decided to go "green" (no one used that term back in the 60's), and built a trash recycling plant where the separated all the cardboard from the metal. They made so much money on the recycled paper that they paid for the plant and its staff, plus a profit. They built a new paint plant and decided to dispose of the barrels of waste paint and other solvents environmentally by building a huge waste oil type burner. Before that, the drums were hauled off to a landfill where they rusted away and leached the stuff into the ground. It was on the old docks from the days when the plant received parts and cars shipped out by barge, and faced up at 45 degrees out over the river. There was big propane flame that got it up to really hot, and a huge blower to rev it up more. Then the paint was thinned down with the used cleaner from the degreasing tanks and other used solvents, and was fed into the burner to be completely combusted. - No waste, No mess, No pollution! Win-Win!!
After many years, the "paint burner" was closed down when the experts realized that phosgene, and likely dioxin, were being blown into the atmosphere over the river.
I love this forum. So much knowledge and those taking the time to share it. I learn something every single day here.
I have a gas forge and would really like to try cable damascus and dont want to have my forge eaten by the borax fluxes so reading through the posts by Stacey I see that either sand or kerosene may be used but all the posts above are pertaining to the stacked plate type of damascus so my question for Stacey is whether soaking in kero for the first heat and using sand for subsequent heats would make for a sucessfull cable weld??
The problem with cable is that you have to burn out all of the crap. Bar stock is or should already be "clean" when you forge weld it
