Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
I wonder if this would work? http://www.harborfreight.com/plastic-welding-kit-with-adjustable-temperature-96464.html
Maybe use a hair dryer? ha ha ha I smell a visit from the Fire Department...
Sorry to tell you this, but if it is either of those two plastics, you're pretty much SOL. The type of polymer chains in those two are extremely slippery, and not much of anything will stick very well to them.
The best thing I've found is Poly-Weld from TAP plastics. Despite what they claim, I have not had the greatest results with it on polyethylene, even when flame-treating the surfaces to prep them. It works for a little while, but then gives way.
I don't know what you're trying to fix, but it sounds like a tank or something since you want it to be waterproof, but you might just have to buy a new part/item. I sought the same thing not too long ago, and was unable to locate a suitable adhesive. YMMV.
PS - Don't bother with the Loc-Tite two-part poly stuff. It flat doesn't work... Complete ripoff IMO. :thumbdn:
Heat.
Yep, I'm Web administrator for TAP plastics, the poly - weld is ok, but that's about as best as you can get with PE plastic. Polycarbonate can be glued pretty well with an acrylic solvent cement like sci-grip weld on 3.
Depending on what the item is just plain old heat welding might work. No direct flame, but if you can localize the heat and get up to about 400°F you might have some luck. Practice on some old milk jugs first.
-Xander
