Best gun cleaning kit
Matthewd
Chief Gadget Officer
What do you guys prefer to use for cleaning and maintaining your handguns?
For maintaining all my guns, at least for barrel cleaning, I use a piece of weed eater string with the end melted to hold a patch on and then pull it through the barrel from back to front. the larger the caliber, the more/larger patches. I for one find that it seems to work better than rods, since it won't scratch my barrel up
Boresnakes, Otis "Toothbrushes", Breakfree CLP, and a Box o'rags thats all you really need. I have some more advanced stuff but this combo will clean 99% of anything you could have
i use the cheapo winchester kits at walmart. i also use Breakfree, Hoppe's and Remmy Oil. its all i need. my rifles and shotgun are 16 yrs old or older. they work great. no jams
"Best" gun cleaning kit is called elbow grease.
I use a mishmash of several kits and cleaning products and they all work, but just need your time & effort to scrub away lead, copper and fouling.
Three bits of advice if you don't already do:
1. Use the next larger bore size brass cleaning brush (9mm -I use .40cal, .45ACP, I use .50 Cal, etc.) as I find it does a better job of scrubbing the barrels. If you only use brass or bronze brushes, it will not harm the barrel in any way.
2. ALWAYS use a muzzle guard when cleaning the barrel. Never know when you might slip and hit the muzzle with your cleaning rod and put a small mark on the muzzle. Something small like that will affect the accuracy of your firearms.
3. Use car brake cleaner (chlorine free version) as a general cleaner on your gun to save some time or as final step. Brake cleaner is the same as "Gun Scrubber" at 1/5 the price. It is just a formula to remove accumulated carbon and grease from metal & plastics and dry with no residue.
i had thought about that for years and never had the balls to try it.. thanks for the input. this sure as hell would speed up my process when i detail shotguns and rifle inards.
Forgot to mention that brake cleaner is OK on plastics but don't get any on finished wood. It will strip the varnish off-of the stocks and grips.
thanks for the heads up. i think thats why i was too scared to try it. but once the actions are broken down and away from wood i could hose them down with brake cleaner. :thumbup:
if you have an AR.... a chamber brush on a "T" handle (rethreaded an old Lewis Lead Remover handle) really helps.... carbon scraper made from small flat blade screwdriver...clean gas ring area with .44mag case...then brake cleaner... be sure to re-lube.... Birchwood Casey Barricade (formerly Sheath) for rust control
Tico tool for shotgun
One caution on brake cleaner - strips off all lube/gunk to bare metal..BARE METAL. Light coat of oil, CLP or similar required right away unless you like your guns with RUST.
