the Lansky is fairly limiting because of the few options in applying the clamp. This also means the angles marked might not necessarily be the ones you get, as the width from edge to clamp will vary knife to knife. Still, I used one for a few years with fair results for working knives.
The Sharpmaker is a very simple setup, but also really slow due to the fine stones. Congress tool sells triangular rods in much coarser grits that will fit, and you could still get in under $50 with some bargain hunting on the SM itself. The only issue in use I can think of is the possibility of rounding your tips if you let your mind drift. You can do a couple things to adjust the angle beyond the two slots, like wedging something under the base to tilt it (you can also put the rods in the bottom as something of a flat stone.
I had an Edge Pro for a while, but just didn't see the benefit where others do. With the extra time to set up the table, get the rest adjusted, set the height on the guide rod, put in the stone, I was still left with the duty of manually holding the knife steady on the table while moving the arm. With bench stones, I put some water on them, and hold the angle steady while I move the knife. A little time practicing at the beginning takes out all the extra time setting up for each and every use of the Apex.
As for the fine Spyderco and stropping, there's really no reason I can think of that the white rods shouldn't leave a shaving edge. Your hair may be very fine, and require something sharper than others. While some people suggest getting a shaving edge before moving on to higher grits, I don't do that until the brown Profile, and I do notice an improvement when stropping even after ultrafine. Still, the white rods should give a good edge that will remove hair.
