The OKC machete is a beast for a machete. I consider it more like a golok in uses I want it for aa it's heavy to swing for a long time. Latin machetes are thin and long so you cut with tip speed qnd the weight is very manageable for long hours of cutting. And they are great for that. It has tradeoffs when you start getting to thicker green wood targets or dry wood. They're really not great on dead drywood, if that's something you need to clear.
For many green wood, a standard machete should be fine up to 1" diameter, maybe 2" for softer woods. I jist finished clearing up a cottonwood blowover and that stuff cuts like grass, just thick. I feel like clearing cattails and reeds is tougher than the cottonwood, but eventually it gets thick enough that the machete needs to be set aside for a different tool. Great for taking the small braches off quickly to make sticks and logs to be hauled out.
Almost forgot, the baryonux machete. It's a beastly beast. It's thin thin but the blade is really weight to add chopping weight. It's a bit clunky to carry around and not something I want to swing all day, but it can hit hard and cuts and chops well. On the right.
