Best on fine leather sheaths?
A prouduct by Bickmore it s called Bick 4. It is a leather conditioner that does not overly soften leather and is safe on all exotics and will not darken leather. It does not waterproof leather but I have found this the best prouduct for all my leather care and like I said it does not soften the leather so it is great for holsters and sheaths. Any tack shop carries it and that is what it was made for and those horse people now how to get miles out of there leather. I have used it on ostrich,buffalo,elephant and even my leather connely seats to great results
Karen Shook has told me to use Beeswax on my privative sheaths. Shes an expert in my opinion. Like to hear from Paul Long on this subject.
After 45 years "doing" leather, including more years than I like to think about doing repairs - IMO one of the best ways to learn what works and what doesn't, I've settled on one conditioner (I use other finishes as protectants/water resisters - but they are NOT the same thing necessarily as conditioning - and with respect to Karen, whose work I admire greatly, beeswax is a top coat good finish but it doesn't condtion the leather) - what do I use?
Lexol Conditioner....
Here's some info on leather conditioning that someone sent a link to ( I hold no stock in Summit or Lexol and understand the following could bes seen as sales pitch but their findings/advice regarding conditioners matches with other qualified sources :
Leather Conditioning Explained
A candid interview with Dr. Don Jenkins and Phil Meyers from Summit Industries (parent company of Lexol)
Dr. Don Jenkins (left) and Phil Meyers, Vice President of Summit Industries (right)
Proper Leather Conditioning
Q. What is leather conditioning?
A. Conditioning replaces the natural tanning oils evaporating out of the hide. The smell of leather comes from these oils. If not replaced, leather will eventually dry out, become brittle and crack. Think of these tanning oils as microscopic, lubricating oils. If you look at leather under a microscope, the fibers look like a pile of rope that's all tangled up. Tanning oils coat these fibers allowing them to bend, move and slip across one another. These oils keep the leather soft and supple. Without lubrication, leather fibers will become stiff and brittle. When repeatedly flexed, stiff, dry fibers will simply break and the leather will develop cracks.
Q. That sounds simple enough. So what makes a good tanning oil or lubricant for conditioning leather?
A. All cow hides are naturally oily. Unfortunately, these natural oils are stripped away in the tanning process (Tanning is the process that renders the hide invulnerable to decay.) and some equivalent oils must be re-introduced after tanning. This last tanning step, the replacement of oils, is called "fatliquoring." Over the centuries, a number of oils have been found that have a natural affinity for leather fibers. Every leather tanner has his own, unique, blend of tanning oils. These formulas are closely held secrets, passed down through the generations. This is one reason why one company's leather can have a totally different feel, fragrance, texture and softness from another company's product. Tanning oils can contain a variety of oils including Neatsfoot oil, Sperm Whale Oil, pressed lard and Lanolin.
Q. I've heard the term Neatsfoot oil. What is it? Where does it come from?
A. Neat is an archaic name for hooved animals (i.e. cows, pigs, sheep). Neatsfoot oil is oil rendered from the feet of cattle or hooved animals. In the slaughterhouse, the feet would be cut off the animal, split, put into a large vat and boiled. The oils that rose to the top would be skimmed off and sold as "Neatsfoot Oil." Today, thanks to the US military, there is no actual Neatsfoot oil in Neatsfoot Oil! Let me explain. Back in the 1930's the US Army wrote a Military Specification (Mil Spec) that defined the properties of Neatsfoot Oil. Oil merchants bidding for government contracts quickly discovered other, less expensive, oils would meet this Mil Spec. Today, Neatsfoot Oil is any oil, regardless of where it comes from, that meets this US Government Mil Spec. Neatsfoot Oil now is mostly derived from pigs. Lard is pressed and the resulting liquid, which can be supplemented with mineral oil and/or reclaimed motor oil, is sold as "Neatsfoot Oil". Neatsfoot oil is widely used in the equestrian industry (saddles and tack) but has no advantage in conditioning the finished leathers found in automobiles.
Q. You make both Lexol Leather Conditioner and Lexol NF Neatsfoot Oil. Which should I use on my car's leather seating?
A. It comes down to personal preference. Both products arrive at the same end result using a different path. The advantage of Lexol NF Neatsfoot Oil is in the equestrian market on, say a blond, unfinished, natural saddle. Lexol Leather Conditioner over time, will darken unfinished leathers about half a shade. NF Neatsfoot Oil will maintain the natural color of unfinished leathers indefinitely. The leathers used in the automotive industry are "finished". There is no advantage or disadvantage of one product over the other. The conditioning oil in NF Neatsfoot Oil is a highly modified oil derived from lard. The conditioning oil in Lexol Conditioner is a synthetic Sperm Whale Oil. Both are excellent conditioners. Since we started in the equestrian market first, we have many "old timers" that will only use NF Neatsfoot Oil. Younger consumers that grew up with the Lexol brand tend to purchase Lexol Conditioner. Again, both products produce the same end result. There is no advantage or disadvantage of either product in the automotive leather market.
Q. I noticed dozens of drums of Lanolin in your raw materials area. I assume Lexol uses Lanolin as a conditioning oil?
A. Lanolin is used for conditioning leather. Ironically, Summit Industries is the third or fourth largest user of Lanolin in the United States yet, despite of our considerable research, we do not use a drop of Lanolin in Lexol products! Our use of Lanolin is reserved exclusively for our skin care ointments. Lanolin has two problems. First, it's very greasy. (Lanolin is produced by the sweat glands of sheep.) Lanolin is the greasy oil that covers the sheep's fleece. Secondly, it loves to migrate. There's no way to keep it in the hide. It loves to come to the surface where it is easily transferred to any material (clothing) it comes in contact with. The complaint that most leather conditioners are "greasy" is typically attributable to the use of Lanolin.
Q. I've seen other manufacturers use banana oil, aloe and collagen as conditioning oils or additives. Are these valid conditioning oils or beneficial in a leather conditioner?
A. (Laugh) Not to my knowledge! Banana oil is commonly used as a fragrance or fragrance enhancement. It will mask chemical or foul odors and add a "sweet" aroma. Banana Oil has no value as a conditioning oil. Collagen is used for human skin reconstruction. I know of no valid reason to put it into a leather conditioner. It is not a conditioning oil. Likewise, Aloe has no value as a conditioning oil. I have never, ever seen or heard of any study that gives any valid reason for putting Aloe in a leather conditioner.
Q. I've seen "Mink Oil" used in leather conditioners. Is Mink Oil a valid conditioning oil?
A. Yes it is. We do not use it in Lexol products but it is a valid conditioning oil. "Mink Oil" is a euphemistic name for liquefied pig fat and silicone. Like Lanolin, it's very greasy and typically unsuitable for leather upholstery. Mink oil is most often used on heavy boots or other hard-working leathers.
Q. Now I'm confused. If all of these conditioning oils are so bad, greasy, what do you use in Lexol Leather Conditioner?
A. The conditioning oils we're talking about, Neatsfoot Oil, Lanolin, Mink Oil, pressed lard oils, are not "bad" conditioning oils. If fact, they are very good conditioning oils. They just have some undesirable characteristics. They are all greasy and they like to move around. In the 1980's, largely from our research in skin care ointments, we discovered a way to modify some of these conditioning oils. We found a way to make the large droplets of raw oils into a microscopically fine emulsion that can be readily absorbed into the leather fibers. We also found a way to keep these oils in place, to greatly reduce migration. This keeps the internal fibers lubricated longer and prevents seepage into adjacent materials like clothing. The oils used in Lexol Conditioner, a closely held secret, make for a very user friendly conditioner that is excellent for leather upholstery.
Q. How is Lexol Leather Conditioner different from other leather conditioners?
A. First, it contains no petroleum solvents or silicones. It is an aqueous emulsion that quickly penetrates into the hide where it is absorbed and retained by the leather's fibers. We refer to the main ingredient in Lexol Leather Conditioner as a synthetic Sperm Whale Oil. This oil provides long lasting lubrication (within the industry, we call this lubrication nourishment) without migration or surface seepage. Unlike most organic conditioning oils, Lexol Leather Conditioner is non-flammable, odorless, non-toxic and non-sensitizing to the skin. It does not impart a greasy or tacky feel to the surface of the leather (unless overused). While there are many fine leather conditioners in the marketplace, we know of no other manufacturer in the world that has been able to match our technology in controlling greasiness or oil migration.
Q. How soon should I start conditioning the leather in a new car?
A. The leather in a new car is fully conditioned. There is no reason to use a conditioner for at least 60 to 90 days. After that, application is somewhat climate dependent. Monthly leather conditioning of cars in Florida, Texas and Arizona, especially during the summer months, would not be out of line. In a northern climate or during winter months the interval between conditioning could be extended 90 to 120 days.
Q. What is the proper procedure for applying a leather conditioner?
A. Clean the leather first to remove surface dirt. Lightly dampen a cotton or Microfiber cloth or applicator pad with water so that it doesn't absorb too much conditioner. Spray the applicator cloth or pad with conditioner and wipe it into the leather. A little conditioner goes a long way. Multiple light applications are better than one heavy application. Wipe the entire leather interior of your car and then allow 20 to 30 minutes for the oils to be absorbed. After this time, lightly buff the leather with a dry cotton or Microfiber cloth to remove any excess conditioner.
Lexol Leather Conditioner maintains the strength, beauty and utility of leather while protecting against the destructive effects of time and the environment. It also brings new life and resiliency to old or neglected leather that has become cracked or hardened.
Lexol Leather Conditioner leaves a soft, satin finish without a greasy, surface residue. For the very best in leather conditioning, insist on Lexol.
Proper leather cleaning.
A continuation of our interview with Dr. Don Jenkins and Phil Meyers from Summit Industries.
Q. How should you clean leather?
A. First let me tell you what not to do. Never, ever use a multi-purpose, high pH, or highly alkaline cleaner on leather. Your better, aniline dyed leathers, the kind used by Mercedes-Benz, BMW, Porsche, Audi and Lexus, should be cleaned with a product in the pH 5 to 5.5 range. That's actually a mildly acidic solution. Most multi-purpose cleaners and spot removers have a pH of 12 to 13. If you spray a multi-purpose, high pH cleaner on leather and buff with a dry cloth, the cloth will often turn brown. The consumer will believe it's dirt coming out of the hide. It's not dirt, it's tanning agents. You are actually detanning the hide! Remember, whatever chemical solution you put on leather remains in it.
Secondly, avoid cleaning or conditioning leather that is hot from being in the sun. Do not spray a cleaner directly on the leather. Use an applicator sponge or cloth to apply the cleaning solution. Spraying a cleaner on hot leather can cause spotting and discolorations.
Q. What is the proper procedure for cleaning leather?
A. Clean one manageable section at a time. For example, with bucket seats, clean the seat back and then move on to the seat bottom.
Wet a washcloth or Microfiber cloth with water, leaving it as damp as you would if you were going to wash your face. Spray the cleaner on the cloth and begin to wash the leather as if your were bathing. Don't forget the stitch lines. Dirt left in the stitch lines can cut through upholstery thread over time but proper cleaning will extend thread life. Especially soiled areas can be agitated using an upholstery or soft leather scrub brush.
After bathing each section, rinse the washcloth to clear it of dirt, wring it out, wipe off any excess cleaner then towel dry with a clean, dry cotton or Microfiber cloth.
Q. What about saddle soap?
A. In the late 1800's the final tanning of leather required the talents of a "currier". This craftsman took the tanned but stiff hide and worked oils into it until the desired flexibility was obtained. This process is called fatliquoring. The fatliquor of choice was an emulsion of oil in soap. This "saddle soap" was not used as a cleaner. It was a softening conditioner.
In fact, saddle soap is a very poor cleaner. It must first dissolve its own oils, limiting its capacity to dissolve dirt and oils in the leather. Saddle soap is also inherently alkaline and alkalinity is damaging to leather. Another problem arises during application. Most saddle soaps instruct the user to work the lather into the leather. Since loosened dirt is suspended in the lather, it is pushed back into the leather's pores.
Saddle soaps have long been replaced in tanneries by modern emulsions which penetrate, soften and condition with greater ease and stability. The popular myth of saddle soap as a cleaner however persists as modern folklore.
Lexol-pH Leather Cleaner is the safer alternative to harsh, alkaline products like saddle soap. Special cleaning agents have been blended to clean leather thoroughly without the damaging effects of alkalinity.
Lexol-pH is balanced to match the pH of leather. This preserves the leather's strength, durability and appearance.
It doesn’t have any chemical odor. If anything, Lexol-pH enhances the original leather smell.
and for more of my own personal observations see here: WRTC Leather Care
On the other hand you'll probably get more varied opinions on this subject as there are products or makers......
Howdy Keith -
Your welcome and yep - I'll shoot you an answer tomorrow to verify, but we're all set as far as I'm concerned...
Chuck's post covered the subject very well from several perspectives. I do use a light application of Pure Neatsfoot Oil as the primary oil finish on all my newly completed sheaths, but I took the direction of the thread to mean more maintainance than new application and once again Chuck's post covered what I would recommend as well. Cleaning the leather thoroughly prior to the application of a conditioner cannot be over stressed.
Paul
In fairness to Karen, she could have very well recommended beeswax to me as a protectant rather than a conditioner. I have used Lexol on leather seats in classic cars for years and have never had a problem. Thanks Chuck.
I have found Lexol products to be excellent. They were recommended by a sheathmaker as well as a friend that rides horses and uses them on her expensive saddles.
I didn't notice a lot of difference between Lexol cleaner and saddle soap FWIW, but I really like the conditioner. There is one conditioner that contains neatsfoot oil(darkens light leather a bit) and one without it.
Peter
I have used Lexol on my automotive interiors for the better part of 20 years. I am a believer.
Roger
What if the sheath hasn't been used, just want to give it a "drink"? Should it Always go through a cleaning first, to remove old conditioning oils? .. i hope not, i like to be as lazy as possible ;)
.. this sounds like talking about which shampoo is Best! haha. (ignore.. )
Thank you for the excellent info. Neatsfoot oil is "no" Neatsfoot oil?, i got the impression (reading Chucks info) it was better before the switch of ingredients.
[Bring back the Colonel's secret recipe,.. Real feet!] ..not the "tastes like chicken" brand. I like it with bits of toenails still floating. And, a shot of tequilla. can't help myself.. :)
David
David, if the sheath truly has not been used or exposed to a dirty environment, then a simple wipe down with a damp, not wet, cloth should suffice. Remember the maintainance coats are LIGHT and more than one only if deemed necessary. (You are prabably thinking, "How do I know if it's necessarry?) If I told you, I'd have to kill you.
Paul
Now that's funny right there I don't care who you are!! :D ;) :D
what about an old, cracked antique sheath? Is Pecards the best?
I won't use Pecards since it is non-organic - I know they say that museum's use it, but I've worked with several museum's over the years and keep in contact with several curator's and I don't know of one that uses it or recommends it :confused:
I hesitate to answer without actually seeing/handling the piece but GENERALLY if not in absolutely terrible shape (i.e. a piece that is not so fragile it can't be handle) I would clean it with the PH Balanced cleaner and then use either THIN coats of Lexol Conditioner (buff lightly in between) or Renaissance Wax, which is extensively used by many museums.
The problem with old leather is not only do the oils dry out, but one is not always sure of what others have used, and the biggest problem of all is pollution - the sulphur in pollution causes a reaction with the products used during tanning that causes irreversible rot in leather :mad:
Paul, :) .. damp with water? I've never heard of that, periodically. is that what you meant? ..don't kill me..
Wild Rose, by pollution and sulfur, do you mean airborne pollution?
Cockroachfarm, it's "Beinenwachs-Lederfledgecreme" .. sorry for my poor spelling. The other brand of treatment i've tried is called "Leather-mate", by Urau, expensive Italian product., the one having lanolin.
Is it true oil, petroleum products will cause irreversable damage to leather, a gradual desentigration? .. i think i ruined a Nice leather handle this way, getting Rem oil on it, the leather and brass spacers developed a bad reaction and the brass continually became green, almost dissolving (over time) with a caking residue which i never found the solution to fix. Anyone had this problem with brass and leather? .. it doesn't happen Always, not sure why leather and brass, or copper, together sometimes have a tendency to produce the green corrosion, anyone have suggestions or comments?
David
David, Yes, damp with water. Actually it's more like dusting the sheath. The object is to have nothing in the way of dirt that the conditioner could carry into the fibers. Now that much was fairly common knowledge, but any more and I WILL have to kill you.
I can't prove it with the written word, but I've had enough old leather men tell me that petroleum based products are not good at all for leather. They said it and I believe them. In fact I will only use pure Neatfoot Oil because the Neatsfoot Compound contains petroleum distillates. The green brass or copper you refer to is "Verdi Gris" (I think that's the correct spelling). It cleans up fairly easily, but it will come back. I've generally seen it associated with oil or conditioner applied in too much quantity and/or too often. I'd like for Chuck to come back in on this one because I'm working from an old and faulty memory.
Paul
Cool thread. Is that the same product one should use for fine shoes?
