Why only one axe? Do you have a weight limitation, because you have to pack it in? Or a $ limit? Or your better half has threatened you? Any one axe that will do all those things probably won't do many or any of them especially well. perhaps a double-bit for felling and limbing, a maul for splitting, and a hewing hatchet for the joints on your log cabin... Just a thought. T-AI'm looking for an axe that's good for splitting, felling trees, bucking wood and is just really good all around. An axe a man can build a log cabin with and split a cord of wood as well. What do you guys recommend?
www.bladeforums.com
Thank you.Read this thread.
If only one axe (or only two, or only three axes)
As written by Peter Vido: This is meant to inspire a dialogue among somewhat seasoned ax users. Naturally, no matter what I might suggest, there will be folks out there disagreeing. I have, in principle, no difficulty with diversity of opinions as long as they are based on actual experience...www.bladeforums.com
I want to be able to just grab that one axe and know it's all I need for whatever I'm doing.Why only one axe? Do you have a weight limitation, because you have to pack it in? Or a $ limit? Or your better half has threatened you? Any one axe that will do all those things probably won't do many or any of them especially well. perhaps a double-bit for felling and limbing, a maul for splitting, and a hewing hatchet for the joints on your log cabin... Just a thought. T-A
Do you have a budget?I want to be able to just grab that one axe and know it's all I need for whatever I'm doing.
Idk if this counts as a budget but anything under a few hundred dollars is preferred but even then I suppose I could justify it if it is a lifelong investment.Do you have a budget?
A good overall axe for the price is this.
Being 68yrs old with a history of shoulder issues, my splitting is done with a noisy gas-guzzler. I've been reminded, as I have been splitting firewood recently, that the straight-grained walnut splits so easily, I could have easily split it with a maul. The elm, on the other hand, doesn't split at all; it just shreds! Even my splitter struggles with it! In your case, might your problems be related to the type of wood you're working with? T-AIdk if this counts as a budget but anything under a few hundred dollars is preferred but even then I suppose I could justify it if it is a lifelong investment.
The council tool seems nice but I have the 36 inch dayton pattern one and I'm having some issues which may not be issues at all with it. Mainly that it doesn't seem to cut deep and I'm having problems splitting some blocks. Might be that the blocks are just too big and the I'm bad at both things.
Wood really is interesting ain't it. It's cool how one piece varies so much to another.Being 68yrs old with a history of shoulder issues, my splitting is done with a noisy gas-guzzler. I've been reminded, as I have been splitting firewood recently, that the straight-grained walnut splits so easily, I could have easily split it with a maul. The elm, on the other hand, doesn't split at all; it just shreds! Even my splitter struggles with it! In your case, might your problems be related to the type of wood you're working with? T-A
That axe and sheath are beautiful. What kind of wood are you typically chopping? Do you think that axe could work for splitting ~8 inch axe cut logs?This is my “Velvicut Bad Axe” from Council Tool as it arrived. 2.25# 5160 head, tempered slightly harder than the standard line. Cost ~$200.
I’m a novice user but have chopped quite a bit over the last several years, and this is my favorite by far.
Big caveat - I’m not splitting with it - really just chopping. I’d definitely want something heavier as a “1 axe” if I were heating my home with wood. For chopping versatility and efficiency though, I like this size.
I found it after much research on this subforum. 3 main reasons:
1) 5160 is my favorite steel
2) The Velvicut premium handles are generally known to be straight and with little/no runout, and thinner than most handles on the US market.
3) Geometry - this is one of very few heads that still has slightly convex cheeks. This is perceptible in the following photos. Using a file to reprofile the edge (after some test-chopping - not bad as delivered) exposes a crescent-shaped bevel. This is because the center of the crescent is thicker/higher than the heel and toe.
I added an adjustable strap, some weatherproofing and an additional snap to the sheath, thinned the handle a bit more, added some tung oil, and now it’s my go-to.
View attachment 2221633View attachment 2221635
Thank you! They’re just cheap hickory hardware store handles. No stain. I thin them all down and rework them a little, sanding and burning as I go. I finish with BLO and wax.NWFRS,
what type of wood are those handles or is the color from a stain? Beautiful work.![]()
A 36" axe is a compromise. The long handle will give it more power for splitting but make it more cumbersome for chopping all but the biggest trees.Idk if this counts as a budget but anything under a few hundred dollars is preferred but even then I suppose I could justify it if it is a lifelong investment.
My “one” axe is a vintage True Temper Dayton pattern boys axe (2.25ish lbs) hung on a 28 inch handle.
For where I can I can do everything with it but it’s biggest area that is lacks is in splitting. I do most of my splitting with wedges and a hammer.
