Hi Sesuko,
So size matters, I thought only women said that
If size really matters then forget about the Polar Pure bottle and get yourseld a small bottle of "Potable Aqua" 50 pills in small bottle.
Here's some text from Doug Ritters Equipped to survive website and deals with your size Dilemma
The most practical commercial products are either "Polar Pure" iodine crystals/saturated iodine-water solution by Polar Equipment or "Potable Aqua" tablets (Globuline-Tetraglycine Hydroperiodide) by Wisconsin Pharmacal. The former is a much better choice if minimum size isn't a criteria, the latter is what is most commonly found in commercial kits. It's smaller and less expensive, but has its disadvantages.
A bottle of Polar Pure will be good for 1,000 to 2,000 qts of water, depending upon clarity of the water. The 50 tablet bottle of Potable Aqua will only disinfect 25-50 quarts of water, depending upon how clear it is. Cloudy water requires two tablets per quart and they now recommend two tablets to ensure killing off Giardia cysts as well, so keep that in mind when deciding how much you should carry. While it is the smaller and cheaper package of the two products, by a significant margin, in the long run the Polar Pure is a much better value. The Potable Aqua tablets have a useful life of about 5-6 years and once the bottle is opened, should be used within 6-12 months because the tablets lose potency after prolonged exposure to fresh air. The iodine crystals in Polar Pure will last indefinitely.
Potable Aqua is now available packaged with a same size bottle of "P.A. Plus" tablets which are used after the water has been treated to eliminate the iodine and iodine taste. They work, but I can't say the iodine tastes all that bad to me. If it bothers you, the additional cost and weight is pretty insignificant. For those using iodine crystals, such as Polar Pure, you can always buy a small amount of sodium thiosulfate at your local chemical supply house and put it into a small waterproof container. A pinch or so per quart will have the same effect. Easier perhaps, Ascorbic Acid (Vitamin C) is also effective for eliminating the iodine taste, but some tablets can take a while to dissolve.
For use in small personal size kits, you may need to re-package the Potable Aqua tablets to fit inside the selected container (such as a tobacco tin, hollow handle survival knife, etc.). However, Iodine is extremely corrosive to almost all metals and also affects almost all common plastics, so neither a plastic bag or plastic vial will work. After years of searching we finally found a solution that's easy, effective, and affordable!
Best scouting wishes from Holland,
Bagheera
