Do you think it will cause more problems if I jump from ten degrees to 3 or 4 since my edge will be so far off the belt? Or will it bo ok since I am mostly watching the bubble and the squareness of the blade to the platen? I'm not watching the edge as closely.
It is just a matter of experience in selecting a grinding angle. Ten degrees to develop the edge is arbitrary. You can start at 5 degrees, which I do a great deal. Many blades can be ground start to finish using the 5 degree setting. Develop the edge at 5 degrees from plunge to tip. The edge should be the same thickness the entire length.
If the blade is going to be ground with distal taper, do so before you start the bevels and you will save yourself a great deal of work.
When you have the edge at just about heat treat thickness try letting the bubble "bump" up against the black line in the bubble vial. This adds 1/2 a degree.
Follow this link to see the other bubble positions:
https://get.google.com/albumarchive.../AF1QipMBibD4spNwRa4UZcy0b5VOdKpeR9I2rZ1-gyyR
Do this instead of actually changing angles by resetting the bubble position. As stated above. I grind many average blades in this manner. Set the bubble @ 5 degrees and float the bubble to increase the grind angle.
With a little experience you will be able to look at a blade and know the angle to use. As stated, it is just a matter of a little experience. The suggestion about watching the spark pattern is dead on. You can watch the bubble position and the spark pattern at the same time. You will get exact bevels with this technique.
Your original question:about doing it wrong by going from this angle to that. NO, there is no wrong in this.
Let me make this point. If I am grinding a large bowie or fighter, 2 1/2 high by 10 inches long: I will start at the 5 degree setting and walk my way down through the angles. A knife this size will end up at 2 1/2 degree bevels if the steel is 1/4 inch thick. The reason I step the angle down 5-4-3 1/2- 3- 2 1/2 is grinding on each of these planes will remove the steel faster because each drop in degrees will have you grinding on the next "high spot" of the bevel. Instead of hogging the entire bevel, you do it in sections. Its faster, I've ground 1000 blades with a Bubble Jig. As I stated earlier, I can grind "free Hand" I can grind faster and much more accurate with a BJ.
You have my 800 number, give me a call if you wish to further this conversation. Fred
