bikerector
- Nov 16, 2016
Thx bikerector . Yeah, I follow JOM/Gravel Cyclist. He's hammered the tire width subject quite a bit. Lots of options in 40+mm these days.
Funny you mention the spreadsheet...I started one of those last year. Much easier to compare the VAST array of options that way.
There are a lot more options in wide tires now. I was looking through some old documents and remembered an article I wrote on cyclocross tires. Back when 32-35mm was big. Everyone racing was on CX bikes with 32mm semi-slicks pumped to the sky. If the roads were loose it was hardtail mtb territory (most people still on hardtails in MI). Much has changed in the 4 years since I wrote this, like bikes called gravel road bikes. Also before tubeless was reliable outside of mtb. Big fan of tubeless for gravel tires, btw. Somewhere around 28-30mm seems to be when I can get tire pressures low enough that when I get a puncture it's not simply a sealant sprinkler head and actually seals up the tire.
http://www.bikewagon.com/blog/cyclocross-tires-what-you-should-know
I will admit, I don't go much over 35mm for gravel tires most of the time. It's not that wider tires aren't better for gravel it's that I rarely have rides that are only gravel and the wide tires aren't as fun on pavement and taking corners fast. There's also the fender clearance thing as my fisti is also my fowl weather bike, until winter. Then it's a felt breed with studded tires and warm beverages.
