Birch bark handle
tattooedfreak
Steel mutilater is more like it.
I have searched and searched and even googled a bunch but I can't seem to find the answer to my question. I have a ton of birch bark and I am wondering what part of the bark to use. I have seen some tutorials that have fairly thin sheets but are they using the paper bark or the under bark? Do I use bark from young trees or older ones? If I use the older ones, I have to dry them flat or they crack while working. What am I missing?
Well I've only done one, so take this with a grain of salt. I have some that's quite thick, about 1/8". It has the paper on it, but also the thick under layer. I think this was off some pretty big trees. It was fire wood, and the bark was falling off on its own. It was curled some, but I could straighten it out with out to much work or any damage. I cut it into 1.5" squares, used a leather punch and razor knife to cut the tang holes. I stacked it all up, tightened my tang nut, ground, then sanded to shape. I coated it with two coats of "Kwik Polly" and done. I brushed the loose, flaky stuff off before I cut it into squares. I cut out lots of imperfections in the bark, but looking back, I think the ones that were left in added character.
I dont know if I answered your questions, but hope this some help. I'll try to find a
Pic of the one I did.
Best luck
Cody
I found the same piece and took some pics of it. It might help.
I've only done this once myself, as described above. I did not Poly it, but just oiled.
Cody - That's some fine looking bark you have there. That will make a great handle.
-Peter (Jealous in Cape Breton)
Is there any reason to glue I between all the layers? I didn't on the one I did, and I doubt they used to. Just wondering?
oh wow, that wasn't what I was expecting at all. Very cool.
I've made two and I lightly brushed each face of bark with slow cure epoxy before compressing. I likely broke all the rules, but I built this one four years ago and its doing just fine.
-Peter
Thanks guys, the stuff I have is a little thicker than that and curled up while drying, I should have tried to keep it flat but I didnt think about it. Maybe I can dampen it a little and flatten it to see if that works. Peter I think you just like showing off...
When I make a birch bark puuko or Saami knife, I use the heavy bark and clean it off with a wire brush. Any loose paper needs to come off. What you have is like a sheet of hard leather - .10" to .13" thick. If very dry, it may split and fall apart, so soak it in water to make it soft for working and compressing if needed.
Bo Bergman's book on "knifemaking" is the authority book on Scandinavian knives. It is pricey, but worth every penny. Many libraries have it or can get it.
Start with cutting out rectangles of the bark. Make them a bit oversize. You can slot each piece stack on the knife tang, and do it in the classic style, or use the trick below. If you use the "stacked on the tang" method, you need to seal the handle, once that it is shaped. The classic way is to soak it in Linseed oil for several weeks and then let it cure over a few months. This works, but many other sealers work as well and are faster. Try using a thinned sanding sealer like woodcarvers use, or use thin CA. Apply several coats, and sand them down, repeating and sanding as needed until all fibers and pores are sealed. Then sand smooth and buff lightly.
Here is a tip/trick I posted about doing one a year ago:
A trick for making stacked birch bark or similar handles is to make a jig for assembly. Make the handle block up and treat it as you would do with a solid block of wood from there.
You punch a 1/4" hole in each square, (soak the bark to soften it if needed), slip the squares on a piece of 1/4" wood dowel, and compress the stack with a wood clamp that has a hole drilled in each jaw ( see below clamp directions). It is a good idea to put a 1/2" thick wooden block and a few layers of wax paper on each end of the stack to keep the handle from gluing to the clamp. Applying wax or white petroleum to the clamp is also smart. Let the bark dry under pressure for a week. Now,while still compressed, soak the stack with thin CA repeatedly until it will not absorb any more.This may take several days of soaking and letting absorb. Don't rush it and don't use accelerator. Take the assembly off the clamp, and rough sand to an oversize cylindrical handle shape, re-clamp and re-soak with CA. After the CA has had a few days to cure completely, drill out the dowel, shape the tang hole, and assemble on the knife. A final sealing with CA before the last sanding will leave a beautiful surface with all the birch bark grain character showing.
You can use a waxed, smooth, stainless steel rod instead of the dowel, and drive it out of the stack, but it can be a trick getting it out sometimes. The wooden dowel is easy to drill out, and works just fine.
I have used this same method to make a stacked handle for a wedding cake knife from cut up pieces of woman's great-grandmother's wedding dress, and another time used a pair of WW2 army boots to make a stacked leather handle for a knife the original boot wearer's great-grandson would take to the Mid-east.
It will work with any material that can be cut, stacked, and glued. Think - Yard sale elephant skin boots, old leather coats, exotic leather scraps,....let your imagination run wild. It is the side view of the stack that will be seen, so the current surface isn't an issue.
You can also make up a batch of handle blanks at one time, and leave the rough shaped cylinders on the dowels...ready for your next projects. This will greatly speed up making a batch of puuko's.
Using the same method with larger rectangular pieces of bark can provide the blocks for a classic puuko sheath.
The tool needed:
Every maker should get a large woodworking clamp ( the type with two screw handles) and modify it for gluing handles. First, disassemble the clamp, and cut a slot in the end of one jaw. The slot should be big enough to allow the ricaso of a hidden tang knife to sit in the slot. Next, drill a 3/8" hole opposite the slot ( in the other jaw). This will allow a stack of things to be compressed and/or glued up on the blade tang. The slot also is great for gluing up solid wood handles to the knife and clamping to allow a perfect ( no gaps) fit while the epoxy dries.
Now, drill another set of 3/8" holes just a bit back from the slot. These holes should align with each other. Use these to clamp up stack of things on a dowel or metal rod.
This clamp will become indispensable in making knives after you have it.
This is a tutorial I found on assembling a birch bark knife on the tang:
http://imageevent.com/paleoaleo/makingabirchbarkknifehandle?p=0&w=1&c=3&n=0&m=45&s=0&y=1&z=2&l=0
Stacy - The knife I made above, was assembled with a pre-formed block of bark sheets much like you describe. I just added epoxy to each layer before compressing. That handle was soaked in Tung oil for a day or so then left to dry for more than a week before final sanding and a final light coat of tung.
I think the real key is to use a good, solid sheet of bark in the first place. If the sheet is at all foliated it will show later in life. I've found good sheets on two year old beaver-downed tress where the wood has shrunk away from the bark making it quite easy to cut and remove.
I really like the feel and look of this material and I plan on working with it again.
Freak - Showing off would be posting a pic of the birch bark welt in the sheath!! :p
-Peter
Stacy I did find that post, the problem Im having is finding the right bark, I either get paper or 1/4" thick. I can't seem to find any of the right size. It must come off young trees. I have tons in the back yard that I am planning on cutting anyway, I will have to check them out. Yes, Peter, that would be showing off...
1/4" thick is OK. By the time you clean it up and compress it, it should look great. You can always sand both sides a bit with 100 grit paper to rough it up as well as thin it down,too.
Its very brittle though, maybe its too dry and I should soak it a bit?
... the problem Im having is finding the right bark, I either get paper or 1/4" thick. I can't seem to find any of the right size. It must come off young trees....
Resurrecting this old thread in the hope that someone in the future Googling this topic can find answers. It reads to me like you are either peeling just the white papery outer layer of bark that the tree is already shedding, or you're getting all the way down to the cambium - which is the layer between the bark and the wood.
What you want is the layer of bark between that cambium and the white, papery outer layer.
To harvest bark successfully, you have to find the right white birch, and you have to find it at the right time of year. If you get the right tree at the right time of year, it's amazing how easily it'll peel. If you get the wrong tree at the wrong time of year, you'll just make a mess.
Go looking when the sap is running - a hot day as the trees are leafing out. If the wild roses are blooming, that's a good indication. Make a vertical cut through the white papery layer and the brown woody layer of bark, but not through the green cambium layer. No horizontal cuts are necessary. Try to peel it off the tree between that brown layer and the cambium layer. You'll know what I'm talking about as soon as you see it, and you'll know right away if that tree is going to peel or not.
A plastic spatula is a great help in the peeling.
Once you get the bark off, layer it between plywood or something and let it dry flat. If you ever need to bend it, heat is what will do it. Water won't make it flexible, unless the water is hot. Birch bark is so waterproof they used to make canoes out of it. You can straighten curled bark by pouring hot water on it, though.
I'm working on a birch bark handle now. I found a dead standing tree about a foot thick that I could push over and sliced off sheets. I soaked the sheets in water to soften the inner wood so I could clean it up easier. The wood was quite soft and punky. A more traditional way if you don't want to glue is stack the layers of bark compressed and heat it in a oven for about 40 mins at 160* F The natural oils in the bark will spread and glue it all together, pretty cool. Plus you don't have to kill a living tree, unless your making firewood as well.
