BK9 Combat Bowie: Urban Commando Mini-Review
A couple weeks ago, I picked up a BK9. Yesterday evening, I got the opportunity to give the knife a good workout after some strong winds knocked a bunch of limbs and branches out of an old maple tree in my rear yard.
I'm pleased to report, the BK9 is a very impressive performer.
FYI ... even though the factory edge had been cleanly buffed and would push cut paper and shave arm hair over most of its length, my Becker came with a somewhat obtuse and uneven grind. As a result, I went ahead and reprofiled the edge shortly after getting the knife, establishing a uniform 16 degree edge bevel per side with a medium India stone, then applying a very light 21 degree secondary bevel with fine ceramic. The steel in the BK9 is a pleasure to sharpen, and I found it extremely easy to produce an edge that would keep Jerry Fisk's mice awake at night.
Prior to tackling the maple limbs, I had done some preliminary testing of the reprofiled BK9 on some pieces of rough/split mahogany and oak, and was delighted with how the knife performed. The knife is a good size for controlled, two-handed work, and the quality of the edge was such that it was little trouble to true and shape these tough, split-prone hardwoods. The mahogany in particular proved to be pretty tough on the black epoxy finish, but the BK9 held its edge through this work, with no perceptible loss in cutting efficiency before I had a big mess of wood shavings on the workshop floor.
When the softer, green maple limbs and branches made themselves available for further testing of the big Becker, I decided to use the knife in ways I might ordinarily consider abusive, just to see how it would perform. With some of the limbs being in the 2-1/2" to 2-3/4" diameter range (stuff I'd ordinarily use a tree saw on) I saw an opportunity to test the toughness of the reprofiled edge with a lot of lateral stress and twisting force.
With little more than a short, brisk swing made mostly with the wrist, my first chop into one of the springy limbs at about a 45 degree angle sank a good inch into the wood -- very satisfying! As I continued, I was genuinely surprised what a good chopper the BK9 is. Blade bite was outstanding at a variety of angles, and while the "sweet spot" for this kind of work clearly seems to be just behind the belly, there was no real loss of control or discomfort even with somewhat errant blows. As is often the case with chopping like this, heavier strokes didn't result in proportionately greater penetration, but would often dislodge pieces of wood. There was no problem whatsoever with binding. Small branches up to 1/2" diameter were easily lopped off, and a number of very forceful chops were made into the larger fare, just to see how the edge would hold up.
When finished, I removed my gloves, and found the edge still very sharp to the touch. A quick spritz with WD-40 and a wipe down, and both the edge and black epoxy coat appeared practically perfect. Later, under magnification, no edge chipping, impaction or rolling was found, and a few quick passes on ceramic rods restored the original sharpness.
Only other comment ... while the Becker handles seem to be a bit controversial, I'm personally finding them to be extremely well designed, and they fit my rather sinewy, medium-large hands very well; in fact, when I first picked the BK9 up after putting my work gloves on, I almost thought the handle could stand to be just a tad longer. But once I began working, I never gave the handle a second thought, and the grip was very secure and comfortable throughout.
My compliments to the good folks at Camillus/BK&T on an excellent product.
Sorry if I was a bit misleading with the 'Urban Commando' thing. ;) I hope this follow-up post will be a bit more relevant to those of you who like to get all cammied up and sneak around the park late at night like I do, terrifying all the lovers, muggers and drug dealers; or, for anyone who might have reason to carry their BK&T from time-to-time.
Just a bit of background ... here in Colorado, any law-abiding citizen who can legally own a firearm is permitted to carry his or her gun, so long as it's not concealed, in and around most public places. And local jurisdictions are no longer permitted to infringe indiscriminately on this right, at least for the most part (or so the law reads; IMO a great deal of discretion is still advisable.)
But when it comes to knives? Nope, anything longer than a 3-1/2" blade is verboten, unless you're hunting or fishing. Go figure: 5" barreled .45 auto with 3 extra mags, no problem; 4" blade, I'm breaking the law.
Anyway, my point being, because of these strange circumstances, I didn't pay a lot of attention at first to the sheath that came with my BK9, inasmuch as I didn't anticipate carrying it around much, anytime soon. I had read several comments where people said their Becker sheaths were loose, and that the blades rattled quite a bit in the Kydex insert ...
... but when I first put mine on, and took a little saunter across the room -- good gawd! It sounded like I was in the middle of a battalion of North Vietnamese regulars, snapping the safeties on their AKMs on and off!
Obviously, I'd either have to fix the sheath before I went skulking around the local park at 1 AM, or carry the BK9 in my teeth all night (illegality of such activities notwithstanding.)
Thankfully, there's the BFC search feature, which turned up the following threads:
http://www.bladeforums.com/forums/showthread.php?threadid=267061
http://www.bladeforums.com/forums/showthread.php?threadid=258265
http://www.bladeforums.com/forums/showthread.php?threadid=254561
http://www.bladeforums.com/forums/showthread.php?threadid=239330
Inspired by the efforts of others -- particularly Jason Burns' trick of shoving a piece of webbing down into the bottom of the sheath -- I put my limited but tenacious mind to cyphering upon the problem, and came up with a slick (IMO) solution.
Part of the problem, I realized, is that it's not only the blade inside the Kydex insert the rattles, but the back of the sheath and insert makes a fair amount of noise slapping against your leg. So merely tightening up the fit of the blade in the Kydex insert doesn't entirely solve the problem.
What I found works great is to take a piece of nylon webbing, about 18"-19" long (for a BK9) and run half of it down the Kydex insert, along the side where the edge goes (away from the spine, which fits the insert reasonably well.) Then fold the rest of the webbing over and slip it down the back of the Kydex insert, between the insert and the nylon fabric backing of the sheath. This tightens up the knife in the insert, and adds noise-reducing padding to the back of the sheath.
Depending on how loose/noisy your knife is, and how tight you want the knife in the insert, you might need wider or narrower webbing. 1" webbing snugs the fit up pretty good for mine; 1-1/2" is nice and tight, just a bit stiff on the draw. (FYI, my basement bunker is full of huge rolls of webbing, paracord, MREs, duct tape, ammo, magazines [both gun and girlie types], grease paint, body bags, etc., so projects like this are a snap.)
So long as you're a bit careful not to cut into the webbing when inserting the knife into the sheath, this little fix-up works great. And of course, if you're like me, you like having your BK&T there, quietly at your side, ready for action.
See you all at Denver City Park! :)
I like the handle on the BK9, I did not like it on the Campanion, though they were the same handle. Strange, Huh?
I think the BK9 sets a new standard for a 9" class knife in terms of bang for the buck. It is a piece any solider or outdoorsman can afford, and can do the job as well as any of the more expensive knives.
Great Job Camillus and Ethan Becker!!!
Pair it with a SAK and you have a great duo for tackling any obstacle.
I believe the BK9 has set some new standards in terms of affordability and durability.
It is big enough to do most jobs and tough enough to last two generations.
The webbing insert work wonders on my BK9. I had a two ft piece of 1.5" wide light webbing and trim it to length. Great idea.
Thanks,
