- Dec 6, 2010
I have heat treated plenty of tooling before, and I always wrap the tools in .002" SST foil with double folds for a tight seal. I did this with the .060" 1075 Blades I am HTing, but It took far too long to unwrap the blades. By the time I was able to get them out they had lost too much heat and did not harden.
1. What techniques do you all use to keep carbon build up to a minimum?
2. If you use foil how are you wrapping the blanks for easy/quick removal?
3. Do I need to Normalize before going through the heat treat process again?
