AFAustin
- Jun 8, 2004
Well, here's my oddball question of the week. I mainly have small traditional folders and more often than I like they suffer from blade rap. That is, the blade will hit the back spring on closing and leave a small ding where the contact was made.
I have 3 methods of addressing this, and will often use a combination---or all 3---to solve the problem. The first is to just sharpen the blade down enough to avoid contact. The problem with this is that it can result in too much metal being lost.
The second is one Gary Graley taught me and that is to insert a small sliver of rubberized cork in the well up next to the tang, which will, in effect, extend the tang and keep the blade from hitting the spring. The problem with this method is that it can result in the tip of the blade (which I like to make very sharp and pointy) sticking up a bit outside the well so that it can poke your finger a little---not good.
The third method is to use a very small diamond file and make a groove in the spring so that the closed blade has a little more clearance. The problem with this method is that it's slow going!
So, here's my question. Could the third method be accelerated by using a Dremel and cutting wheel to make the groove? Obviously, you'd need to use a light hand and be very careful not to cut too deep. I have a Dremel and a couple of the small cutting wheels, but have never used them and am no pro with the Dremel in general, so I'm a little uncertain about charging ahead.
Any advice or experiences would be appreciated. Thanks.
Andrew
Andrew
