The only time you are getting fleeced is if a company advertises X steel and sells you A steel.
Otherwise it's called advertising. Everything you buy is advertised and hyped as the best. Your car, clothes, TV, the little blue pill, even the screen you're looking at now. There's as much hype going on here as the manufactures put out.
The fan boys of simple or low carbon steels who try and tell you they are better than supersteels and anything else is unnecessary. The super steel fans who say anything less is liner materal. The argument about need is worthless, need has nothing to do with what you want.
Heat treat vs geometry vs steel all things being equal steel trumps all. It's the combination of heat treat, geometry and steel that determines how an edge performs. Geometry being equal D2 at a 61 or 57 HRC is going to out perform AUS-8. It would take a truly excellent heat treat on AUS-8 and a truly awful heat teat on D2, to make those two steels perform the same. The same applies to geometry. It's possible to put such a bad geometry on D2 that you negate most of the advantages you get from the steel.
The video the OP posted compares S30V, 1080, and 8cr13mov and says he can't tell the difference. All I can say is there is something wrong with his test. In edge retention 1080, and 8cr13mov aren't even close to S30V. Yet some will take what is a flawed test and quote it as the final word.
All steels have characteristics that set it apart from another steel. 420J2 is stainless and easy to sharpen on anything handy but won't hold an edge long. S90V holds an incredible edge much longer than 420j2 and it's easy to sharpen with the right tools and knowledge. 1095 is much tougher than S90V but isn't stainless. With all steels you get a little and give a little, it's up to the user to educate themselves. If you don't educate yourself you'll feel like you got fleeced. You didn't but you'll feel like it.
You can't have a steel discussion without asking the question, better at what use, or for who and their uses. Sometimes you may want a super steel or a simple carbon steel and you don't have to justify that to anyone.
It's a great time to be a knife nut, there are choices that didn't exist when I started carrying a knife in the late 60's. Today I can choose a barlow in 1095 or M390, or a modern in AUS-8 or S110V, as well as the modern traditionals coming out.
I would like to see more discussion on a steels characteristics and geometry and mush less useless chatter about simple steel vs super steel. Geometry and steel characteristics are two things that are not well understood by many.
D2, AUS-8 and 1095.
D2, AUS-8 and 1095.
