Is it BIAS to weaken the edges on knives on the high carbide steels to the point that they will fail in the purpose to promote the lower carbide steels?
Provided you're also honest about where high carbide steels excel (higher angles, abrasive mediums, still thin cross sections), then NO. It is simply discussing metallurgy and let someone, the end user, decide what they need.
Kinda like making a chopper out of S90V, thinning the blade down to 0 behind the edge and smacking a rock with it then going see what happened........ It chipped out and or cracked.... I mean DUH... Really?
Again, I have no problem with this, even if you compare it to a chopper made out of S7 or 1055, provided that you at the same time state this is what one would expect to see based on the metallurgy. However, it should be noted that based on that same metallurgy S90V would make an excellent slicing blade.
Similarly, testing a bunch of steels (both high edge stability and HCV) against each other at low edge angles (talking under 10 dps) is fine. It simply shows the adequacy of some for those angles of use. It does not negate the efficacy of HCV steels at higher edge angles on slicing abrasive medium. If someone were to state that, then there would be bias. Otherwise though it is simply testing of proposed metallurgy.
Some people show those comparisons at higher edge angles on abrasive medium (yourself included) and that's great. It does not however negate the fact that some steels excel at lower angles at high polishes for push cutting.
Or why not just even the plane across the board and use something like 10 Degrees per side, or 15 Degrees per side, more in line with actual edge geometry that most people would actually use if there isn't any BIAS.
Why not just drive mid size sedans at that's what most people drive? Some people have different needs. Some people are simply interested in the experiements.
If we want to base things on "common use" though, why not make everything the edge angle of shaving razors or utility blades, as I imagine those are some of the most used blades.
In my way of thinking an unbiased test and or research project the field has to be leveled so none of the subjects being tested have an unfair or unrealistic advantage and or disadvantage. So the parameters of the testing would be neutral or in the case of edge holding one would use the normal edge geometry that most would actually see. That would be 15 DPS or 20 DPS as an average as most factory knives in that range give or take.
How is your testing fair to chopper blade steels? By extension then, how can your testing necessarily be fair to high edge stability steels meant to excel at lower edge angles.
By the metallurgy (and if you look at the data sheets for the other intended use of the knife steels in question...and it is important to note with the exception of AEB-L none of these steels were made specifically for knife use) using 15dps or 20dps is giving the HCV steels an advantage.
Beyond that the fact that most knives come with those DPS does not mean they are ideal. Again, the ideal car choice was based on America cars, everyone in the world should drive larger sized cars. In Europe though that is hardly the standard. And in Japan such high edge angles are not the standard either, but then again they tend to use much higher edge stability steels so you would expect lower edge angles.
However, I can say your testing is useful for people who are going to maintain those initial and common 15dps and 20dps edges. If that is going to be the case, then people are going to see a lot of mileage from the HCV steels. That does not mean though that it is fair to other steels.
In reality, it is impossible using these steels on an even playing field. Saying that is like saying all rope was intended for climbing...so the way to evaluate rope is to see what can be climbed most easily. Paracord as a result is awful. These steels were not developed for knife use, but by looking at their intended uses we can see how they would perform for certain types of knives. Comparisons between them is to 1. reinforce their adequacy for certain tasks 2. and to see if are understanding is limited somewhere.
Now yes if one wants to narrow the scope of the research down to make a specific point or address a certain narrow set of variables then that's fine too. Document that fact clearly that it was narrowed down that far and why and say what point it was ment to show.
Like the efficacy of certain steels for cutting rope and cardboard? Knives are used for much more tasks with very different modes of blunting...cutting wood, chopping wood, splitting wood, cutting meats, vegetables, etc.
En fin, again, what bothers me are the blanket statements and the insinuations that other people have an agenda when people here are making those same blanket type of statements. Such blanket statements are detrimental in general and discredit the wide variety of useful steels and the areas in which they excel.
My last comment on this will be the following, as I don't want this to turn personal.
AEB-L, a high edge stability steel was specifically designed for razor blade steels....quite some time ago. Do people really think metallurgists just failed to realize the usefulness of throwing in a bunch of carbides into that steel? And that we knife users discovered their mistake? Or perhaps, it does better without them at low edge angles, high polish and push cutting...
And considering the amount of money spent on razor blades too, and their high costs, I don't think we can simply say it's a cost issue and that's why they don't use "super steels"
