I've replied to you on the other thread about the Hapstone system.
As far as stones are concerned, have a look at the dual sided Venev diamond resin stones from Gritomatic. They are excellent stones, and will give you value for money unlike any other stone set for the price range or well beyond. They are rated in FEPA-F grit, so don't make the mistake to think that their 1200 grit stone is coarse, it's actually equal to about 5000-6000 grit in the JIS grit rating that most people tend to quote.
The Boride T2 stones are going to be limiting with some modern steels you may want to sharpen, especially high Vanadium carbide steels like your S110V PM2. With the Venev stones, you will be able to sharpen any steel.
They have a very affordable 0.6 inch set, just recently added:
Venev Ursa Series Dual Side Diamonds are used for sharpening knives on Hapstone and TSProf guided knife sharpeners, as well as freehand sharpening. Diamond sharpening stones offer excellent performance in sharpening knives of any steel.Ursa Series is 16 mm wide dual side diamond with two 1...
www.gritomatic.com
They also have a 1 inch set:
Venev Centaur Series Dual Side Diamonds are used for sharpening knives on Hapstone and TSProf guided knife sharpeners, as well as freehand sharpening. Diamond sharpening stones offer excellent performance in sharpening knives of any steel.Centaur Series is dual side diamond with two 1 mm-thick...
www.gritomatic.com
And lastly, you were asking about stops in the other thread. Gritomatic also have a very well priced set of diamond pastes for any stropping you may want to do :
Diamond Compound is a very effective method of honing and polishing the cutting edge of the knife. Diamond is the hardest commercially available substance on Earth. Diamond Compound consists of synthetic diamond powder. In case you are not sure what grit you need for your work, you can use the...
www.gritomatic.com
If you get yourself the Venev diamond stropping paste, it works very well on leather - but it needs to be warmed up with a hairdryer to let it penetrate nicely and melt evenly after you apply it to your strop for the first time. (it's wax based).
