David Boye BDC and BDS Lightweight Lockback Folders
3" blade - 4" closed
BDC = Boye Dendritric Cobalt (non-steel - cast cobalt alloy)
BDS = Boye Dendritic Steel (cast 440C)
Zytel handles
spoke to David Boye on the phone today and he is just doing his "Boat Knives" - which are the BDC Cobalt folders - the style above (blue handle) which used to be called the "Prophet" - now he just calls the pointed-tip boat knife, and the only other style of the Boat Knife is a sheepsfoot serrated blade folder - see his website:
http://www.boyeknives.com/
David does all the grinding and hand finishing on these knives.
Any other styles of knife is now a special order -
he can still make them - but one has to contact him for the special order.
The Eagle wing folder is in BDS steel which is a cast 440C - and this is one of my sharpest and "cuttin'est" knives ever.
It is a very shallow hollow-grind that continues to thin toward the edge.
I specifically asked David about his hollow-grinds and why so many others do hollow-grinds that thicken toward the edge (which is kind of self-defeating the whole point of a hollow-grind).
He explains that he grinds down to 1/1,000th**[note: this is WRONG please see CORRECTION below] of an inch and uses a rather large wheel grinder of 20" vs. the usual 10" wheels.
I questioned about grinding so thin - wouldn't this ruin the temper of the blade as the there is so little material to dissipate the heat. He said it shouldn't and one can always use water for cooling.
** CORRECTION [edit 9/3/2003]** - perhaps I was wrong about 1/1,000th of an inch -
perhaps he said 10 thou and I mis-heard or had wishful thinking working....
see also David Boye's own specs where it says 0.010" or 10 thou.
http://www.boyeknives.com/technical_info.cfm
I went and searched my old rec.knives posts where David had 0.012" edge thickness in his old brochures - and when I spoke to him then he told me he could get down to 0.008" - that is 8 thou
rec.knives thread on Boye's Blades Re: Blade thickness - Date: 1998/01/16
My apologies for the confusion.
Vincent
http://UnknownVT2005.cjb.Net
http://UnknownVT.cjb.Net
http://UnknownVincent.cjb.Net
Zytel handles
Vincent
