Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Can you, yes. Should you? I wouldn't. The whole point of using oil on a stone is to prevent particulates from loading the surface, and while breakfree would do that it would also end up soaking the stone in teflon particles, which over time I would imagine may lead to glazing problems. I would sooner use WD40 on a hone than a teflon containing product.
I don't know what it'll do since it has teflon in it, but I do know that you'll be able to get a sharper edge without oil anyways. Particulates from the stone and from the edge float in the oil and collide with the edge of the knife as you sharpen. It ends up putting little micro chips in the edge and as a result your knife doesn't get as sharp as it could...
I have read this theory before and it just doesn't make sense to me. How much resistance can a floating particle offer to an advancing edge other than its own inertia in the viscous oil? If the edge is so delicate that it could suffer "micro chips" from coliding with floating particles, then what could such a delicate edge cut beyond soft butter with out being chipped? It just doesn't make sense.
If the particle is harder than the edge it scrapes and chips it head on, I guess when you have alot of particles it chips the edge a whole bunch. It doesn't really make a difference unless you're trying to get a ridiculously sharp edge.
