- May 12, 2001
Thanks to my buddy, Burnsy56, I was privileged to receive a couple of Brian Goodes knives to briefly play with. Brian has posted some of his blades for sale in the maker's forum.
The companion set of Brians Trailsman and Sidekick arrived to me with the Piggy back sheath for two, and a separate sheath for the little fellah. Brian crafted the piggyback sheath so that it could be uncoupled if desired, leaving the Trailsman sheath solo. A very nice touch. The kydex sheaths were well-fitting and nicely made. A webbed nylon belt strap was attached to the sheath, but it could be removed for IWB or pocket carry of the knife(s). Youd need a good sized pocket for the Trailsman.
Steel O-1, Brian shoots for an Rc of about 58 for the edge as hardness that is a good balance between edge holding and ease of sharpening. Blades had a nice full flat grind with a convex edge. I stropped the edges some to bring the edge to a higher level of sharpness. Out of the box the blades would easily cut paper (a nice working edge) but I prefer my knives even sharper. Specs on the two knives:
Trailsman
Blade Length: Approximately 5.75, tip to handle
Blade Width: Just over 1 ¾ at the widest point
OAL: 11
Weight: 9.6 oz.
Balance point: Middle of the index finger cut-out in the handle
Sidekick
Blade Length: 2 7/8
OAL: 6 3/8
Weight; 3.25 oz.
Balance point: Rear cusp of index finger cut- out in the handle
Piggy back sheath: 4.8 oz.
Sidekick. Started cutting tests with little guy, on some fairly sturdy cardboard. All cuts were made perpendicular or diagonal to the grain. I cut a pile of cardboard as pictured, until the blade started to drag some. It was pretty easy to bring the edge back to the sharpness before cutting with a few swipes on a fine Spyderco ceramic rod and some stropping on a piece of cardboard loaded with compound.
Next, I proceeded to do some wood work with the Sidekick, making fuzz sticks from heavily resinated fatwood. The blade performed well, making curls of any size desired. After cleaning off the gummy resin from the fatwood, some well-aged Douglas Fir was attacked. The blade bit aggressively and carved off smooth curls. As you can see from the picture, the cuts are good and clean. By now, the little blade had dulled some. About half a minute stropping with cardboard loaded with compound brought the edge back to nice and sharp.
In the kitchen, the Sidekick was a great little slicer, though a bit thick for real delicate cuts. Very nimble because of it's shorter handle.
Trailsman
OAL: 11
Weight: 9.6 oz.
Sidekick
Blade Length: 2 7/8
OAL: 6 3/8
Weight; 3.25 oz.
