Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
I'm not speaking of true bronze alloy. Bronze anodized titanium, does this still apply?Bronze forms a greenish-brown patina not unlike copper, as it oxidizes.
Is bronze Ti hardware long lasting? Or wear off quite quickly? I'm primarily going with Ti hardware due to the difficult lanyard tube on the Spyderco Paramilitary line.All titanium anodizing will wear over time. The fading is caused by abrading the top oxide layer (that has the color) or any oils on the surface that changes in how the light hits the oxide layer. The brilliance of the color can be restored by stripping away any oils from the surface with windex, if that doesn't work you can have the piece re-anodized.
It depends on a few factors, notably how often you touch it or it rubs against other things. Anodization on, say, a screw that sits proud of the scale and is in a spot your hand uses as part of your grip will wear off much more quickly than a recessed screw that never really touches your hand, pocket, etc.Is bronze Ti hardware long lasting? Or wear off quite quickly? I'm primarily going with Ti hardware due to the difficult lanyard tube on the Spyderco Paramilitary line.
Beat me to it. I was just about to post a pic of my sebenza as an example tooIt depends on a few factors, notably how often you touch it or it rubs against other things. Anodization on, say, a screw that sits proud of the scale and is in a spot your hand uses as part of your grip will wear off much more quickly than a recessed screw that never really touches your hand, pocket, etc.
As an example, the anodization on the peak of the thumb stud on my Sebenza 31 has worn off, the ano on the raised "steps" of the stud has partially worn off, but the ano on the "valleys" has not, nor has the ano on the lanyard plug.
If you don't like the idea of anodization wearing off eventually, don't buy anodized hardware. IMO that wear is part of its charm and half the reason to use anodized parts.
Yes. The bronze in the alloy will discolor. Titanium oxidizes naturally, but it is opaque and uncolored. The colored anodizing effects on titanium are artificially created with heat.
No actual bronze in anodized titanium.
If we want to get specific, the thickness of the oxide layer increases proportionally based on the voltage applied.Is bronze Ti hardware long lasting? Or wear off quite quickly? I'm primarily going with Ti hardware due to the difficult lanyard tube on the Spyderco Paramilitary line.
No problem man. It said it in the title Titanium.The OP never said it was anodized titanium in his initial post, and I obviously missed it in his subsequent post.![]()
