I have questions...
Acid blueing/patina: I got a very nice, even and smooth, dark grey finish on a CS Master Hunter with just lemon juice. At just the right angle, I could literally read the newspaper in its reflection. Birchwood-Casey's Perma Blue is selenium dioxide, an acid. The main ingredient in mustard is vinegar, acetic acid. Its viscosity makes it interesting to play with. People seem to report the darkest , most even patina with regular yellow French's, and milder reactions with the spicy brown stuff. Anyone know if this is just due to vinegar content, or other factors?
Alkaline patina: "Sodium hydroxide, solution is also known as caustic soda, liquid caustic (solutions of 45-75% sodium hydroxide in water), lye, soda lye, sodium hydrate. This easy to use formula produces the deep blue-black finish most desired by custom gunmakers. A mixture of 6 1/2 - 7 lbs. per gallon of water will boil at the correct processing temperature at 275 degrees - 280 degreess F. No other additivies are necessary. Temperature is vitally important to bluing, therefore an accurate thermometer is a must. Process parts about 15-30 minutes to produce a beautiful, durable black oxide finish." My apologies to the author, I don't remember where I find it or who wrote it. Do any of you use lye? Or other alkaline solutions?
I've seen some posts lately by folks using layers of different patinas, and trying it out myself. You can get some nice, kind of case-hardened-looking finishes this way.
