- Jan 27, 2008
I have a very small, simple, basement shop along with my propane forge and a few woodworking machines in a backyard shed. Not having a surface grinder, and relying on my eye mostly to gauge "flat" and "true" makes this project especially challenging for me. However, tackling a brute de forge, full tang fighter has been on my list for quite a while and the chance to build one as part of a mirror-matched set provided just the right opportunity. One polished finish, forge finish for the other - both with Ebony and Thuya burl handles, front and rear bolsters, carbon fiber and s.s. pins. I'll just be showing the brute de forge build as I haven't taken many photos of the polished build, but the template is exactly the same.
While forging this blade, the 9 yr old boy from down the road stopped by. I let him pound away on the blade for a few heats and you'll see his contribution in the form of many of the ball peen marks. I wanted to give the exposed blade flats some texture so I had him beat some dings into the blade faces. As well, when forging the blade I wasn't able to drawn the steel down quite as far as I wanted to get the full length of the finger guard I had envisioned, so I had to re-draw the handle template to accommodate the available steel.
So here I go.....
1/4" x 1 1/2" W2 from Aldo:
First few blows to start shaping the tip:
Blade is forged and cooling from its first normalizing cycle:
Roughly profiled:
Dialing-in the profile:
Draw filing to true the faces:
Handle faces need particularly careful attention so as not to mar the forge finish on the blade flats:
Roughly flat and true, now I can clean up the profile:
Now Dykem blue applied to scribe in the grind lines. I use a file guide to scribe the plunge lines accurately:
I use a marble slab and an appropriately sized drill bit to scribe the edges:
Raised clip first. I use a variety of angles wooden block jigs to get this job done. This blade will be 20 degrees:
I use a worn 60 grit belt for the rough grind, then a 120 grit to clean it up. One side almost there:
T'other:
Now the bevels:
First passes to knock the edge down to the scribe lines:
Almost there:
One side rough ground with a fresh 60 grit followed by a fresh 120 grit:
Bevels are done:
And the flip side:
The bevels have been ground. Now I can hand sand the handle faces to a smooth and flat, to 180 grit:
Now more Dykem blue to layout the tang arrangement:
That where I'm at tonight. This is a bit of a daunting task for me as I need to get the handle slabs/bolsters to fit up perfectly or it'll look like crap. But, that challenge is what makes this so engaging and fun for me.
I would greatly appreciate any feedback, tips, etc.
More tomorrow.
-Peter
So here I go.....
Roughly profiled:
T'other:
Now the bevels:
Almost there:
Bevels are done:
And the flip side:
More tomorrow.
-Peter
