- Aug 14, 2006
i was very excited to getvany of these and do some testing in the outdoors with them,I can say after some good solid use that the ceracote blades' coating does not hold upwell at all,even with gentle use it wears off quickly .The original coating from black widow was the best DLC coating I've seen on a blade,which makes we wonder why Buck Knives would use ceracote knowing it isn't as durable .
I still have and use original ag knives from when they first came out with the series ,and the coatings are still like new,showing little if any wear on the blades coatings.
I used my new ceracote 110 to cut some cardboard boxes and coating has worn away wuite a bit just from that,also in the pivot area from opening/ closing it has worn a fair amount.
I brought it out lobster fishing in the atlantic for 3 weeks and now the coating is almost a bronze color compared to the black it was before,also the blade is rusting a fair amount from the salt which was normal I guess once the coatings wore off,but the original dlc coating I had tested held up to the salt no problem and really did a great job at corrosion resistance.
I sure hope Buck will go back to the original dlc coating that was not just for looks,as this new ceracote from what I see is only for looks,offering little rust resistance as The coating wears away much too fast.
