What do you all think of this knife:
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
That type of knife i would imagine will sit in a collection. Maybe a few will be used here and there but I doubt many. Great collector piece.What do you all think of this knife:
Buck Legacy Collection 110 S45VN blade steel, Marble Carbon Fiber Handles with Gray Aluminum Bolsters - Limited Edition. it seems to be a limited edition for 2021 only. I think it is a great looking knife. The pictures of the marbled carbon fiber are amazing. S45VN is a great new steel for us to play with. At $200 or so, this knife isn't cheap, but it looks more expensive than its price. It even has screwed together construction!
I’m not sure what the relationships that user to be in place. Does the interactive chat even work anymore in the website? I’ve been checking and no luck since Kevin isn’t there anymore.I ordered one of these when I saw them in the 2021 catalog back in early January from my Buck dealer. I'm still waiting, I contacted my dealer and he said Buck will not even return emails to answer his questions as to when they will fill these orders? I also, contacted Buck via email and have no response as to when I can expect this knife order to be filled. A bit disheartening as Buck is selling these on their web site and not filling their longtime dealer orders. I'm a bit frustrated as this feels like the same Buck customer service as the BCCI take apart 112 deal I paid for and waited for a year then got sent my money back due to a canceled order. Only to have Buck then sell that same knife off their web site a few months after the 112 order was canceled. I would just Like Buck INC answer the question as to when this order placed in January will be filled and shipped?
Some blades work fine. Most do not. Either too tight or loose. Every combo I’ve tried has had a certain degree of sacrifice in action.That's the beauty of the modular knife. If you don't like the blade, change it. Same with the handle. Pocket clips and thumb studs can be added or subtracted.View attachment 1571907
I have had a few problems with blade exchanges where bushings and blades were not matched for thickness. It's best to keep blades together with their original bushings. Most problems arise with aftermarket blades that are sold without bushings.Some blades work fine. Most do not. Either too tight or loose. Every combo I’ve tried has had a certain degree of sacrifice in action.
Black paint can mess anything up, but it’s not too hard to remove ( from the pivot). You NEVER want a blade swinging on painted surfaces.The black paint on the red micarta take apart can cause issues as well.
Vibratite Vc3thread locker is ideal for this application. You apply it to the threads and let it dry before assembly. Then it retains its thread locking ability through many on off cycles. Making it so you can adjust the screw without loosing the thread lock. Plus it’s not a liquid when you instal the screw so there is no chance of it seeping into the pivot.I have had a few problems with blade exchanges where bushings and blades were not matched for thickness. It's best to keep blades together with their original bushings. Most problems arise with aftermarket blades that are sold without bushings.
However, the Legacy and the Club knife do not require a bushing in the blade, and the pivot is adjustable. The only extra step is a little blue LocTite to hold the adjustment when the sweet spot is found.
Sent me on a web search. I never heard of this stuff before. It won't replace my use of Loctite blue (and occasionally red), but for items that you might want to make small adjustments to, this stuff looks great. Good infoVibratite Vc3thread locker is ideal for this application. You apply it to the threads and let it dry before assembly. Then it retains its thread locking ability through many on off cycles. Making it so you can adjust the screw without loosing the thread lock. Plus it’s not a liquid when you instal the screw so there is no chance of it seeping into the pivot.
Will check it out. Thanks.Vibratite Vc3thread locker is ideal for this application. You apply it to the threads and let it dry before assembly. Then it retains its thread locking ability through many on off cycles. Making it so you can adjust the screw without loosing the thread lock. Plus it’s not a liquid when you instal the screw so there is no chance of it seeping into the pivot.
so if you remove the pocket clip on this model, will the pocket clip fasteners thread back in?That's the beauty of the modular knife. If you don't like the blade, change it. Same with the handle. Pocket clips and thumb studs can be added or subtracted.View attachment 1571907
