Buck modifications
David Martin
Moderator
I'll follow 300's posting on Buck mods. This is 103 modified to a throw back of Buck's 110 heavy skinner from the early 50's. I liked that style of Al's era and since I couldn't find one I made one. DM
David, I can see why you like it. It looks a little bit like the new 113 Fixed blade Ranger skinner only better. I really like the handle. What is the size of the blade?
Those models had 4" blades. I also gave it a more generous handle at the pommel and a lanyard hole. Thanks, DM
Very nice touch with those red white and blue spacers.
Classy knife you got there! Great work!
David, you did a good job on that knife... I like the sheath... How long did it take you to modify it???
Thanks for sharing and that's a good picture too... ITE
I did it some time ago and it seems like 3 weekends worth of work. Also, I went back with a stainless pommel and that is harder to work than the aluminum. Then I gave it the edge 2K grind (its a 73-80 three liner w/ the thick edge) as Buck still does upon request and removed the hump. Someone posted here 2wks. ago about taking these apart so, just thought I'd help them. It was a fun project. Thanks, DM
David, that's an awesome job you did. And the shape of the 103 is great.
If I find a 103 with a bad handle I would copy your work. But there are only knives
with bad blades and good handles, not other way round. and I'm not able to
destroy a good looking handle from a good knife. That's a pity. ;-))
Best,
Haebbie
You did an awesome job, ive got a 119 with a broken tip and id love to try something just like this. Do you have a before photo? what does it take to disassemble the handle?
Thanks Gentlemen. Arms, 1) drive out the pommel pin and everything slides off. This is what some say. Ha, problem is I've not found ONE that came apart when I did this. (Buck uses good glue). So, I held it in a vise and using a ordinary wood saw I sawed 3 cuts into the handle all the way to the metal, flipped it over and did the same. Once this is done I used a 1/2" chisel to carefully cut and chip the phelonic away from the tang. Then sand off the remaining glue. Be careful to try and save the finger guard with its spacer and the pommel or you'll have to build another. With this model I wanted to add some length to the handle and allow for a lanyard hole. So, a new pommel I knew I'd have to make. Stainless takes a nice polish but for your 1st try I'd use aluminum round stock 1-1.125" diameter as its much easier to work. For the leather: Using fresh thick leather I took a piece of top rail chainlink fencing pipe, sharpened one end w/ a round file and hammered it thru the leather. You'll need around 17-18 disk. These run 1$ each in most knife supply catalogs. Then I used a 426 Bucklite (with its thin clip blade) to cut the rectangles in the center of each disk. They need to fit tight. I used neats foot oil to treat the leather disks before installing. The colored spacers are a must as they add a nice touch of classy color to the leather. These can be made from anything from old credit cards, colored plastic bowl lids, ect.. The white one above I made from a retained motel room key. After obtaining a round bar stock suitable for the pommel, drill three holes in a row in the end and file this opening to fit the blade tang. The pin hole is 5/32" and you'll need a short piece of round stock for this. Put enough disks and spacers on the tang so the pommel has to be pressed on. Put some glue in the pommel hole press it in place and drive in the pin and swedge it in place. Let it set over night then start shaping the handle with files and sandpaper. I did photograph the process using my phone. I'll have to download those pictures later. DM
Earl, Thank you. After adding handle length it wouldn't fit the original flap over sheath. So, I had the spare 402 Custom sheath, I tried it and it fit nice. A wrap around style 103 sheath would be a good fit as well. DM
Thanks HK. I think you posted a photo of a 1950's 110 skinner that I shaped it after. Yours had a lignum vitae handle and the blades are close. DM
Thanks, Dave for your encouraging words. Or should I call you Grandpa this week? DM ;)
