Looking to get into the dangerous game of buffing blades *shudder*.
Just wanted to make sure I was set up properly. I ran a search and came up with a wide variety of combinations of speeds and wheel sizes. I ran across an old post describing how to calculate surface speed.
Of course my main concern is safety and I don't want to be going to fast (or to slow).
My set up is roughly the same as described in the quotes... 3500 rpm, 6"x1/2" wheel (Med. Felt w/Veritas® Honing Compound).
3.14 x 6" dia = 18.84"
18.84" / 12" = 1.57'
1.57' x 3500 rpm = 5495 Surface feet per minute
If my math is right (it's been a long time since grade 4 math
) then I should be with in the realm of acceptable buffing limits. Yes? No?
Just wanted to check to see if I was in the safety zone and see if this was a common setup.
Thanks.
Nats
Buffer RPM is only part of the successful buffing formula.
Steel polishes best when the surface speed of the buff is at least 5000 Surface feet per minute.
Surface feet are calculalted by taking the circumference of the buff in feet and multiplying it by the buffer RPM.
A 3450 RPM buffer with a 6" diameter wheel will give you the proper speed to buff with.
Thanks.
Nats
