I waited anxiously for my new knife to arrive. It was the Bugout with M390 steel dressed up in beautifully milled 6061-T6 Aircraft Aluminum scales. Amazing that it is a mere 2.5 oz. Out of the box and into my hand, ready to rock. I went to thumb flick it and nothing happened. The blade was stuck, locked into position. My heart sank, I was expecting elation instead I got aggravation.
I grabbed the blade and pulled it out, it resisted but finally yeilded. I exercised it, thinking CPR but it became apparent that it was DOA. This was not going to be a case of breaking it in. I tried anyway, only to be disappointed. I could see a gray sludge around the part of the blade that forms the pivot. I thought, “what kind of lubricant were they using?”
Not to be disappointed any further, I took matters into my own hands. I loosened the pivots and screws on the scales, enough to get significant blade play and swished the pivot end of the knife in 99.9 pct Isopropyl alcohol. Not the stuff you can get in the local pharmacy, this has zero water, it is pure. I could see the gunk washed into the alcohol. Took the knife out and used compressed air to clear out and dry off the alcohol. Then I got some KPL ultralight oil into the pivot and some KPL heavy oil onto the axis bar that rides on the blade and into the detents. Just a few drops of oil, tightened the scales and readjusted the pivot. Perfectly centered and wow the action is unbelievable. The thumb flicks, reverse (spydie) flicks and wrist flicks (unlocked) are amazing. The blade closes so easily and without crazy bounces. Finally the perfection that I was expecting. This knife is amazing, I am elated.
My other Benchmade knives arrived in good condition, I was not expecting this and was going to send it back but gave it a whack. By the way this is a beautiful knife, the below picture doesn't begin to do it justice. No upgrades are required.
Anyone else run into a new knife with gummy lubricant?
