- Jun 11, 2006
After seeing travis's little 1x30 belt bevel grinder I have wanted to build one. What started me down this path was the weird motor I found in the recycle bin. At first glance it looks like a standard 1HP 3hp but further looking reviled that it's different. It says 60hz rpm 1750 then says max rpm 6000. I have not seen this on a motor befor. It also has a 6:1 gear box on the shaft and a 110v fan on the other end. It also has a built in encoder on the fan side. The 6000rpm is what got me thinking about using it for the tiny 1x30 grinder. I would strip off the gear box and keep the fan maybe and see if I could use the encoder with a vfd. So if any of you know anything about this motor that would be helpful.
My next issue is where to acquire contact and drive wheels that are 1" wide. Preferably not super pricy wheels so I can get a few for different hallow radius. I'm thinking about running it up to around 6000sfm max.
Any one build one of these or have any ideas on how to pull it off in a simple, clean and vibration free manner.
Thanks guys
Thanks guys
